I have both radiator heating and air conditioning heating in a room and want to automate activating both heat sources one after another. First heat the room up with radiator to 18 degrees C. When that temperature is reached, activate the air conditioner for heating to 20 degrees C.
It seams that my automation script is not working but keeps waiting. When I test the template in Developer Template the condition is True.
Can you one of you tell what I am missing?
alias: "Klimaat: Verwarming kamer Damon via Button"
description: ""
- platform: state
entity_id:
- input_boolean.verwarming_kamer_damon
to: "on"
- platform: state
entity_id:
to: "off"
condition: []
- if:
- condition: trigger
id:
- Verwarming Aan
then:
- service: evohome.set_zone_override
entity_id: climate.zolder
setpoint: 18
duration: 0
- wait_template: >-
wait_template: '{{ states('sensor.zolder_temperatuur_in_de_ruimte') |
int >= 18 }}'
continue_on_timeout: false
- service: climate.turn_on
entity_id: climate.zolder_2
data: {}
- service: climate.set_temperature
hvac_mode: heat
temperature: 20
- if:
id:
- Verwarming Uit
then:
- service: climate.turn_off
data: {}
- service: evohome.clear_zone_override
mode: single
Kind regards,
Marc
