I’m totally new to HA, and trying to install it its becoming a nightmare.
I’m using a Raspberry Pi 4B and a 64gb Sandisk Extreme microSD card. I’ve followed the steps, using Balena Etcher to flash the HA image (tried v.6.6, both 64 and 32 bits - and v6.2 64 bits I found on Github). I’ve tried with the USB stick CONFIG/network/my-network file…no luck
It’s always the same point where it gets stuck, 'A start job is running for Wait Until Kernel Time Synchronized (1min 28s/1min 30s). It runs out of time and gives a FAIL on the left (instead of an OK). It keeps on loading and I’m able to see the ‘Preparing Home Assistant (this can take up to 20 minutes)’ but stays in there forever.
Connecting the Rasp. to a screen it seems to be working though, the ‘ha >’ in green waiting for a command is okay. It also shows a free IPv4 adress (192.168.1.135/24).
ANY hints??
Gratefull in advance
