i’m trying to put the custom timeout in Wait until Node.
that is in HA Package
In best way i would like to out there a msg.data.timeout or somtrhing like this. But it do not work.
I have read manual
and tried to do this way. But it also do not work. Here if inject Node
All the same it do not override given timeout.
Is it a bug in Wait until Node or i’m doing smth wrong?
Here is the complete code
[{"id":"cf239ad9.c76598","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"7b200786.6e8a88","type":"inject","z":"cf239ad9.c76598","name":"","props":[{"p":"payload.timeout","v":"5","vt":"num"},{"p":"payload.timeoutUnits","v":"seconds","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":200,"y":210,"wires":[["ed6806b2.ea1bd8","88f77850.edce78"]]},{"id":"ed6806b2.ea1bd8","type":"debug","z":"cf239ad9.c76598","name":"1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":470,"y":135,"wires":[]},{"id":"bcf5d455.be4718","type":"debug","z":"cf239ad9.c76598","name":"2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":515,"y":285,"wires":[]},{"id":"1c399e9c.2c8f91","type":"function","z":"cf239ad9.c76598","name":"Cancellation Message","func":"msg.tts = {}\nmsg.tts.message = \"Действие отменено!\"\nmsg.tts.speaker = \"media_player.google_home_mini_livingroom\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":610,"y":195,"wires":[["ed6806b2.ea1bd8"]]},{"id":"88f77850.edce78","type":"ha-wait-until","z":"cf239ad9.c76598","name":"CANCEL Action","server":"63f11f83.adf4c","outputs":2,"entityId":"script.system_cancel_trigger","entityIdFilterType":"exact","property":"state","comparator":"is","value":"on","valueType":"str","timeout":"111","timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":380,"y":210,"wires":[["1c399e9c.2c8f91","ed6806b2.ea1bd8"],[]]},{"id":"63f11f83.adf4c","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Thanks a lot!
