Hello All,
I need some help on how to get some code properly working.
Setup: Sonoff POWR controlling power to dehumidify. HA has generic_hygrostat in config.
Goal: When HA sends switch.turn_off to the Sonoff, make sure the compressor has been off for an x amount of time.
How I’m trying to do this: In ESPHome yaml file, keep track of number component int when power used is within a range with interval. When turn_off is sent, ESPHome will use wait_untill before turning off power to dehumidifier.
The Problem: I see the number component updating but it seems the wait_until isn’t waiting for the condition to be true.
The code:
esphome:
friendly_name: $friendly_name
on_boot:
priority: 800.0
then:
- number.set:
value: 0
- platform: cse7766
update_interval: 1s
current:
voltage:
power:
on_value_range:
- above: 80.0
then:
- light.turn_on: switch_led
- below: 80.0
then:
- light.turn_off: switch_led
energy:
number:
#internal: True
max_value: 1000
min_value: 0
step: 1
optimistic: true
switch:
- platform: gpio #turn off
restore_mode: ALWAYS_OFF
internal: true
pin: GPIO04
on_turn_on:
- logger.log: "Waiting for compressor to turn off"
- wait_until:
number.in_range:
above: 180.0
- logger.log: "Compressor has turned off"
- delay: 100ms
- switch.turn_off: relay_off # bi-stable relay so no need to keep on
- number.set:
value: '0'
interlock: [relay_on]
interval:
- interval: 1s
then:
if:
condition:
sensor.in_range:
above: 10
below: 100
then:
- number.increment:
cycle: false
I’ve tried to follow examples in the online docs but it seems to elude me with combining if, wait_until, and number.in_range I get errors since wait_until is an action. Any help would be greatly appreciated.
Thank you
number.in_range
Condition
# in a trigger:
on_...:
if:
condition:
number.in_range:
above: 50.0
then:
- script.execute: my_script
wait_until
Action
# In a trigger:
on_...:
- logger.log: "Waiting for binary sensor"
- wait_until:
binary_sensor.is_on: some_binary_sensor
- logger.log: "Binary sensor is ready"
Edit: added platform: cse7766 for clearity of sensor source w_sensor
zoogara
(Daryl)
January 15, 2024, 10:54pm
2
Not sure where you define this - obviously you need to ensure it’s value is valid.
Is there some reason a simple delay:
action wouldn’t work?
on_turn_on:
- delay: 180s
Sorry about that, w_sensor
is a valid source.
Edited the code to include platform: cse7766
of the source w_sensor
to remove any future confusion.
A simple delay wouldn’t work since I don’t have any communications from the dehumidifier and how the dehumidifier works is it’ll turn on the compressor and if there is any build up of ice internally, it’ll run just the fan to defrost it as a fail safe.
To get any internal sensor feedback of the dehumidifier would require hacking the unit and would void warranty. By monitoring the power usage, it’s possible to determine which state the dehumidifier is in.
When HA sends the switch.turn_off signal, I’d want the controller to locally determine when it’s safe to cut the power to it.
Here is the entirety of the code, which is a bit different from the top since I’ve been working on trial and error so it doesn’t reflect the original post.
substitutions:
friendly_name: POWR320D
base_name: powr320d_1267
esphome:
on_boot:
priority: 800.0
then:
- number.set:
value: 0
- number.set:
value: 0
esp32:
board: nodemcu-32s
wifi:
ssid: !secret wifi_ssid
ap:
ssid: $base_name
manual_ip:
static_ip: 192.168.8.219
gateway: 192.168.8.1
subnet: 255.255.255.0
captive_portal:
logger:
api:
services:
- service: turn_off
then:
- wait_until:
sensor.in_range:
below: 80
- delay: 180s
- switch.turn_off: relay_1
- service: turn_on
then:
- switch.turn_on: relay_1
ota:
web_server:
port: 80
ota: true
js_url: http://192.168.8.123:8123/local/www.js
uart:
rx_pin: GPIO16
baud_rate: 4800
time:
- platform: homeassistant
number:
#internal: True
max_value: 1000
min_value: 0
step: 1
optimistic: true
#internal: True
max_value: 10000
min_value: 0
step: 1
optimistic: True
- platform: cse7766
update_interval: 1s
current:
voltage:
power:
on_value_range:
- above: 80.0
then:
- below: 80.0
then:
energy:
- platform: total_daily_energy
name: $friendly_name Total Daily Energy
power_id: w_sensor
- platform: wifi_signal
name: $friendly_name Wifi RSSI
update_interval: 60s
- platform: uptime
internal: True
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
name: $friendly_name Power Factor
device_class: power_factor
lambda: return id(w_sensor).state / id(v_sensor).state / id(a_sensor).state;
binary_sensor:
- platform: gpio
pin: GPIO00
internal: true
filters:
- invert:
- delayed_off: 10ms
on_click:
- max_length: 350ms # short press to toggle the relay
then:
switch.toggle: relay_1
- min_length: 360ms # long press to cycle display info
max_length: 3s
then:
- if:
condition:
binary_sensor.is_on: page
then:
binary_sensor.template.publish:
state: OFF
else:
state: ON
- platform: template # this is a fake sensor to tell the screen which info to show on display
publish_initial_state: true
internal: true
display:
platform: tm1621
cs_pin: GPIO25
data_pin: GPIO14
read_pin: GPIO26
write_pin: GPIO27
lambda: |-
if (id(page).state) {
it.display_voltage(true);
it.display_kwh(false);
it.printf(0, "%.1f", id(v_sensor).state);
it.printf(1, "%.1f", id(a_sensor).state);
} else {
it.display_voltage(false);
it.display_kwh(true);
it.printf(0, "%.1f", id(wh_sensor).state);
it.printf(1, "%.1f", id(w_sensor).state);
output:
- platform: ledc
pin:
number: GPIO18
inverted: True
switch:
optimistic: true
turn_off_action:
- switch.turn_on: relay_off
turn_on_action:
- switch.turn_on: relay_on
internal: true
pin: GPIO04
on_turn_on:
if:
condition:
wait_until:
number.in_range: #currently in error state while working on it
above: 180.0
then:
- delay: 100ms
- number.set:
value: '0'
- platform: gpio #turn on
internal: true
pin: GPIO02
on_turn_on:
- delay: 100ms
- switch.turn_off: relay_on # bi-stable relay so no need to keep on
interlock: [relay_off]
- platform: restart
text_sensor:
icon: mdi:clock-start
- platform: wifi_info
ip_address:
ssid:
bssid:
light:
- platform: monochromatic
output: led
internal: True
- platform: status_led
internal: True
pin:
number: GPIO05
inverted: True
interval:
- interval: 1s
then:
if:
condition:
sensor.in_range:
above: 10
below: 100
then:
- number.increment:
cycle: false
- interval: 30s
then:
if:
condition:
wifi.connected:
then:
- light.turn_on: wifi_status_led
else:
- light.turn_off: wifi_status_led
- interval: 100ms
then:
if:
condition:
sensor.in_range:
above: 20.0
then:
