Wait_until: wont compile
I have this…
            - wait_until:
                condition:
                  lambda: |-
                    return 'id(fish_food_hopper).state <= id(post_dose_weight).state';
… and it passes validation.
But on installing I get a compilation error:
Compiling /data/feeder/.pioenvs/feeder/src/main.cpp.o
/config/esphome/feeder.yaml:288:14: warning: character constant too long for its type
What is it trying to tell me?
Try it without the quotes:
            - wait_until:
                condition:
                  lambda: |-
                    return id(fish_food_hopper).state <= id(post_dose_weight).state;
Or use quotes around everything when it is on a single line:
            - wait_until:
                condition:
                  lambda: 'return id(fish_food_hopper).state <= id(post_dose_weight).state;'
Thanks, Tom.
Still the same with both of those options :confused:
Or, I should add, a myriad of other, probably longshot, syntax options.
I’m not sure where to go from here.
Does the lambda seem correct?
I’m getting the same result using while: then:.
Is it the types of fish_food_hopper and post_dose_weight that are causing the problem?
  - platform: hx711
    name: "Fish food hopper"
    dout_pin: 27
    clk_pin: 26
    filters:
      - calibrate_linear:
        - 9800 -> 0
        - 435000 -> 5.0
      - sliding_window_moving_average:
          window_size: 5
          send_every: 5
    update_interval: 2s
    unit_of_measurement: gm
    accuracy_decimals: 1
and:
globals:
  - id: post_dose_weight
    type: int
    restore_value: yes
Some progress in that I now have a different error.
What is…
Condition must consist of key-value mapping! Got return id(pre_dose_weight).state <= id(post_dose_weight).state;.
                condition: !lambda |-
                  return id(pre_dose_weight).state <= id(post_dose_weight).state; [source /config/esphome/feeder.yaml:287]
…trying to tell me?
I now have in my code:
            - wait_until:
                condition:
                  !lambda
                    'return id(pre_dose_weight).state <= id(post_dose_weight).state;'
Don’t quote multi line lambdas. Only quote the whole line when it’s a single line lambda like my example above and just like jinja in Home Assistant.
Try asking on the ESPHome Discord, lots of expert helpers there: https://discord.gg/mdT9Kr9V
It would probably help, if you’d post your whole code. :slight_smile: To see what’s wrong, it is at least necessary to post the parts around the error. Eg. if you forget a “;” at the end of statement, the error normally is set in the next line after… :wink:
Again, thank you both for the help. I appreciate it.
Here’s the whole thing. There’s some cruft and test code in there. I was at it until the early hours.
It was all looking good and working until I started to add the wait_until:.
esphome:
  platform: ESP32
  board: esp32dev
  platformio_options:
    board_build.f_cpu: 80000000L
# Notes
# 5000g maximum tared weight
# 500g minimum weight
# 2 gms per second feed rate
  on_boot:
    then:
      # read the RTC time once when the system boots
      - ds1307.read_time:
      - if:
          condition:
            sun.is_above_horizon:
          then:
            - binary_sensor.template.publish:
                state: ON
          else:
                state: OFF
api:
i2c:
  sda: 19
  scl: 18
dallas:
  - pin: GPIO23
    update_interval: 60s
sun:
  latitude: !secret latitude
  longitude: !secret longitude
  on_sunrise:
    - then:
          state: ON
  on_sunset:
    - then:
          state: OFF
logger:
web_server:
  port: 80
  auth:
    username: admin
    password: !secret OTA_password
ota:
wifi:
  ssid: !secret dryderdale_wifi_SSID
  password: !secret dryderdale_wifi_password
  ap:
    ssid: "Feeder Fallback Hotspot"
  power_save_mode: none
captive_portal:
globals:
  - id: feed_amount_timer_variable
    type: int
    restore_value: no
    initial_value: '5'
  - id: feeds_per_day_variable
    type: int
    restore_value: no
    initial_value: '5'
  - id: water_pre_dispense_time_variable
    type: int
    restore_value: yes
    initial_value: '5'
  - id: water_post_dispense_time_variable
    type: int
    restore_value: yes
    initial_value: '5'
  - id: current_hopper_weight
    type: int
  - id: pre_dose_weight
    type: int
    restore_value: yes
    type: int
    restore_value: yes
time:
  - platform: ds1307
    # repeated synchronization is not necessary unless the external RTC
    # is much more accurate than the internal clock
    update_interval: never
  - platform: homeassistant
    # instead try to synchronize via network repeatedly ...
    on_time_sync:
      then:
        # ... and update the RTC when the synchronization was successful
        ds1307.write_time:
    # on_time:
    #   # Every hour when sun is up
    #   - seconds: 0
    #     minutes: 0
    #     then:
    #       - if:
    #           condition:
    #             and:
    #               - sun.is_above_horizon:
    #               - binary_sensor.is_off: disable_fish_feed
    #           then:
    #             - script.execute: dispense_food
  - platform: hx711
    dout_pin: 27
    clk_pin: 26
    filters:
      - calibrate_linear:
        - 9800 -> 0
        - 435000 -> 5.0
          window_size: 5
          send_every: 5
    update_interval: 2s
    on_value:
      then:
        - globals.set:
            value: !lambda 'return x;'
    name: "Fish feed amount"
    entity_id: input_number.fish_feed_amount #defined in homeassistant
    on_value:
      then:
        - globals.set:
    name: "Feeds per day"
    entity_id: input_number.feeds_per_day #defined in homeassistant
    on_value:
      then:
        - globals.set:
    name: "Water Pre Dispense Time"
    entity_id: input_number.water_pre_dispense_time #defined in homeassistant
    on_value:
      then:
        - globals.set:
    name: "Water Post Dispense Time"
    entity_id: input_number.water_post_dispense_time_HA #defined in homeassistant
    on_value:
      then:
        - globals.set:
    name: "Water temperature"
    entity_id: sensor.pond_water_temperature #defined in homeassistant
  - platform: dallas
    address: 0x0301192A83D1AC28
    name: "Feeder Water Temperature"
    icon: mdi:temperature-celsius
text_sensor:
  - platform: sun
    name: Sun Next Sunrise
    type: sunrise
  - platform: sun
    name: Sun Next Sunset
    type: sunset
binary_sensor:
  - platform: gpio
    pin:
      number: 17
      mode: INPUT_PULLUP
    name: "Manual Fish Feed"
    filters:
      - invert:
    on_press:
      then:
        # - switch.turn_on: fish_feed_motor
    # on_release:
    #   then:
    #     script.execute: dispense_food
  - platform: gpio
    pin:
      number: 16
      mode: INPUT_PULLUP
    name: "Disable Fish Feed"
    filters:
      - invert:
    name: "Fish feeder sun is up"
    name: "Disable fish feeding"
    entity_id: input_boolean.disable_fish_feeder #defined in homeassistant
    entity_id: input_boolean.manually_feed_fish #defined in homeassistant
    on_press:
      then:
        - delay: 1s
        - homeassistant.service:
            service: input_boolean.turn_off
switch:
  - platform: restart
    name: "Restart fish feeder control"
  - platform: gpio
    pin: 21
    name: "Fish Feed Motor"
    inverted: false
    restore_mode: RESTORE_DEFAULT_OFF
script:
  - id: dispense_food
    then:
      - if:
          condition:
              - binary_sensor.is_off: disable_fish_feeding
          then:
            - globals.set:
                value: current_hopper_weight
            - globals.set:
                value: !lambda return 'id(pre_dose_weight).state - id(fish_feed_amount).state;'
                service: switch.turn_on
                  entity_id: switch.water_fill_valve
            - delay: !lambda 'return id(water_pre_dispense_time_variable) * 1000;'
            - wait_until:
                condition:
                  lambda: |-
                    return id(current_hopper_weight).state <= id(post_dose_weight).state;
            # - delay: !lambda 'return id(feed_amount_timer_variable) * 1000 /2;'
            - switch.turn_off: fish_feed_motor
            - delay: !lambda 'return id(water_post_dispense_time_variable) * 1000;'
                service: switch.turn_off
Getting back to where I was originally, I have:
            - wait_until:
                condition:
And this creates the following error:
/config/esphome/feeder.yaml: In lambda function:
/config/esphome/feeder.yaml:296:67: error: request for member 'state' in 'post_dose_weight->esphome::globals::GlobalsComponent<T>::value<int>()', which is of non-class type 'int'
In file included from src/esphome/core/application.h:8:0,
                 from src/esphome/components/api/api_connection.h:4,
                 from src/esphome.h:2,
                 from src/main.cpp:3:
src/esphome/core/helpers.h: In instantiation of 'esphome::TemplatableValue<T, X>::TemplatableValue(F) [with F = esphome::globals::GlobalsComponent<int>*; typename std::enable_if<(! esphome::is_callable<F, X ...>::value), int>::type <anonymous> = 0; T = int; X = {}]':
src/esphome/components/globals/globals_component.h:60:3:   required from 'void esphome::globals::GlobalVarSetAction<C, Ts>::set_value(V) [with V = esphome::globals::GlobalsComponent<int>*; C = esphome::globals::GlobalsComponent<int>; Ts = {}]'
/config/esphome/feeder.yaml:198:64:   required from here
src/esphome/core/helpers.h:239:57: error: invalid conversion from 'esphome::globals::GlobalsComponent<int>*' to 'int' [-fpermissive]
   TemplatableValue(F value) : type_(VALUE), value_(value) {}
It’s the “which is of non-class type 'int” and “invalid conversion” parts that has me think that this is not just a formatting issue.
Does the problem lie with my sensor and globals declarations maybe?
The fish_food_hopper sensor has accuracy_decimals: 1, which suggests it is of type float, whereas the globals are of type int. I have tried them as float with same result though. The sensor doesn’t support changing type.
EDIT:
Removing accuracy_decimals: 1, according to the docs, causes the sensor to return int.
With this, and globals set to int, I now get this error:
invalid conversion from 'esphome::globals::GlobalsComponent<int>*' to 'int' [-fpermissive], which further suggests to me that it’s a mismatched type or similar. Just not sure how to fix it.
Having painstakingly commented out each line of code, one by one, and compiled each time, I’ve narrowed it down to the commented out items in the script below.
I think I’m at the end of my current capabilities!
Any suggestions welcome.
script:
  - id: dispense_food
    then:
      - if:
          condition:
          then:
            # - globals.set:
            #     id: pre_dose_weight
            #     value: current_hopper_weight
            # - globals.set:
            #     id: post_dose_weight
            #     value: !lambda 'return id(pre_dose_weight).state - id(fish_feed_amount).state;'
            # - wait_until:
            #     condition:
            #       lambda: 'return id(fish_food_hopper).state <= 0;' #  id(post_dose_weight).state;'
            - delay: !lambda 'return id(feed_amount_timer_variable) * 500;'
Discord sorted it out!
the .state is not required for the globals, just the sensor.
Thanks all for your help.
