"Waiting for home assistant cli to be ready"
I am trying to get Home Assistant setup on a Protectli Vault, which is just a mini PC with 4 ethernet ports (model VP2420). I have followed Home Assistant’s official guide for installing and have gone with “method 1”.
I am able to successfully install it using this method, however when I boot the machine up for the first time since flashing the Home Assistant image, it boots up and everything and loads all the Home Assistant stuff, but then just gets stuck at “Waiting for home assistant cli to be ready”. To clarify, at all times, the machine has an ethernet cable hooked up to my network.
I am unable to find a solution online, I found one about renaming “dev/disk/by-label/hassos-data-old” into “/dev/disk/by-label/hassos-data”, however it is already labelled “hassos-data” so this doesn’t apply to my case.
I cannot figure out why it is getting stuck at “Waiting for home assistant cli to be ready”. Any help would be greatly appreciated. Thank you
