Waiting for Supervisor to startup
Issue 1: I had a successful install yesterday, finally after many many attempts. My laptop had a system update and when I went to launch HA, I’m faced with this. Any ideas where to go from here?
Issue 2: My chrome says “This site can’t be reached” help please and thank you.
Thank you in advanced.
Have you fixed this problem yet. I’ve got a similar problem where my HA says: “Waiting for Supervisor to startup…”
Hi. I’m in the same boat, did you get it to work and what solution did you use?
It just happened to me too.
It started with Supervisor reporting a fantasy IP address (171.36 …) then when I clicked exit to … exit without saving, I got a sad mac and nothing works anymore.
This was before updating to 2024.6
I’m going to try and reconfigure Network Manager from the CLI
type ‘login’ at the # prompt
type ‘banner’ at the ha> prompt
this typically resolves it if you’ve waited a sufficient amount of time. Why it happens is unclear to me
‘jobs info’ will also tell you what supervisor is up to. You may see a bunch of restart and repair items. These can take a while. Sometimes I’ll just issue ‘reboot’ if it is taking too long. That typically helps when it boots again (still need login/banner typically). I have about half a dozen add-ons and more integrations than I can count.
This problem still exists
Just ran into the same problem. Typing login fixed it.
OS Version: Home Assistant OS 15.2
Home Assistant Core: 2025.5.2
Installed on a Proxmox VM with Proxmox helper scripts
I ‘fixed it’ with an “ho shutdown”. After which, a power up. 2025.5.3
HA in virtual box on Ubuntu on a remote computer.
The following is just interesting:
First I couldn’t access HA.
I couldn’t ping the virtual machine
I couldn’t VNC to the remote computer
I could ping the remote computer
I couldn’t ssh into the remote computer
A day later, desperate, VNC was successful!!?? But the Virtual Box had terminated
Rebooted the remote computer
Virtual Box started, but HA showed this error, thus my ‘fix’
The remote computer is also running mosquito and SIP (sustainable irrigation platform, an irrigation front end) and Real VNC server
Maybe the fact you called it names convinced it to cooperate :wink:
That’s probably true because I swear at the computer so it will behave, using words like awk grep and sed and words that regularly expressed with s/^[0-9]*\t(final)/\1first/g
I have the same error.
Could someone help me?
You don’t need to call the login command. You simply need to call the ha supervisor logs command, as mentioned in your screenshot.
Full silt of commands for supervisor are here Common tasks - Operating System - Home Assistant
