2024-06-16 15:19:49.120 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/green-homeassistant:2024.6.3: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/green-homeassistant:2024.6.3/json: Not Found (“No such image: Package green-homeassistant · GitHub”)
2024-06-16 15:19:49.122 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
I logged into system. And they sent me already faulty system
Too many layers of docker overlay image.
I connected keyboard / monitor and this image 2024.6.4 cant be installed even docker pull -command… so I payed ready installed system but it is broken
What you are experiencing is a network issue, since your green can’t connect to github.
Make sure that you’re connected to the network. Ideally use a cabled connection for this.
Make sure the DNS server your network uses allows a connection to github. You should be able to grab the DNS server your HA is using by typing ha network info with the keyboard & monitor you conencted. You’ll find this under the ipv4 > nameservers section.
