I would like to wake my esp32 based voice assistants with a small zigbee button, but i am unable to figure out how?
Since the device does not seem to have any input button in the home assistant interface to trigger listening. I assume i need to modify the the ESP-Home yaml, and add an input button to be exposed to HA.
But that’s a bit beyond me atm.
Anyone know how to do this?
Or have other solutions?
It works! Thank you!
And that’s really close to what i want.
I’ll need to tweak it so it’s more of a one time trigger.
As is is now, it will await multiple commands in succession as long as the toggle is active. And i would prefer a single command, pr. button press.
Also I’d like to try to get it to not always reactivate the wake word when the toggle is turned off.
But instead return to whatever the previous state is.
For anyone curios on what the entire config looks like, here is my fork of the ESP-Home firmware repo including the nice addition @will35 so kindly shared.
You could just remove the ‘continuous’ from the - voice_assistant.start_continuous, couldn’t you? So it is - voice_assistant.start. I have such a switch and it will just listen for one command.
Definitely curious about how to achieve the other things you mentioned.
