Good day everyone…
I have used this lovely feature a lot and all the sudden it is not doing it anymore.
Did i miss an upgrade that deprecated something or changed syntax?
Til it stopped i had “wake_on_lan:” in my configuration.yaml (not sure if i actually need it in there or not)
And a Button Card with the following code:
I checked my logs after searching for solutions and i get this:
Logger: homeassistant.components.homeassistant
Source: helpers/config_validation.py:1200
integration: Home Assistant Core Integration (documentation, issues)
First occurred: 21:34:28 (2 occurrences)
Last logged: 21:39:43
The wake_on_lan integration does not support any configuration parameters, got [{'url': '/hacsfiles/ha-card-weather-conditions/ha-card-weather-conditions.js', 'type': 'module'}, {'url': '/hacsfiles/lovelace-card-mod/card-mod.js', 'type': 'module'}]. Please remove the configuration parameters from your configuration.
But i dont have any obvious reltionship with this weather card and wake on lan…
Could there be a bug in the weather card that prevents my wol?
With every other tool i can start the PC, so it is not the computer in question…
I did test with the switch code below and a button that is below that:
Finally found an option that works…
The switch as a toggle does wotk but throws an interesting error…
"Failed to perform the action switch/turn_off. Not a valid addon-on slug for dictionary value @data[addon]
But the code for the switch does not have any turn off in it
I’m using the following and it works with no errors logged. No broadcast_address used.
switch:
- platform: wake_on_lan
# Wake on Lan Only works on hardwired connections - no WiFi
host: LGwebOSTV.local
mac: b4:b2:91:d4:f3:11
Edit…
This is the code from Developer Tools - Actions:
