After my update to HASS 92.2 I had problems starting hass. After lot of testing, because no errors shown, I found that a problem with the wake_on_lan config breaks the config. Latest version without problems was hass 0.90, any changes I missed?
Looks like the turn_off part makes the problem, but no idea why. Was working in the lasts years without problems.
Also the custom components (Alexa media player and custom updater both latest versions) block my hass from start.
After removing the custom components and wake_on_lan config it starts without problem.
But I need this stuff so how can I get it back working?
There have been a bunch of info in the last few releases about chainging the way custom_components are setup within the directory.
Start there and work your way to current.
I use the wake on lan component and don’t recall needing to adjust it recently. Can you share your config? Another of the changes happening recently is that HA use to ignore bad configs, now it is documenting them in the logs and not ignoring them which can break things.
For custom components I removed custom updater and loaded latest version of Alexa media player, has the service and manifest file. But still blocks starting.
Here is my WOL config, worked in the last years without problems.
If it helps I could generate a full log output. I could not find any problems in log. Not about wake_on_lan or any custom components like Alexa media player.
