Wake On Lan Failure
My Wake On Lan switch has stopped working of late. I’m running Hass OS (32-bit) on a Pi. It was working flawlessly prior to 0.74.
Anyone else getting similar issues?
Error executing service <ServiceCall switch.turn_on: entity_id=['switch.wake_on_lan']>
  File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1038, in _event_to_service_call
    await service_handler.func(service_call)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/switch/__init__.py", line 109, in async_handle_switch_service
    await switch.async_turn_on()
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/switch/wake_on_lan.py", line 87, in turn_on
    self._wol.send_magic_packet(self._mac_address)
AttributeError: module 'wakeonlan' has no attribute 'send_magic_packet'
same problem. did you solve?
No. I raised an issue:
https://github.com/home-assistant/home-assistant/issues/15756
Got it working by deleting the deps folder.
