I am running Home Assistant os on a mac mini A1347 using the Generic x86-64 (NUC) image, the device is working fine without any issues at all, the only problem i have is in case of power outage i need to be at home to turn on the machine since wake on LAN is not working , any idea how i can enable the WOL on the mac mini?
Has anyone figured that out?
Unfortuntetly no , i tried everything in Os to make it wake on Lan but didnt found a solution , the only way i thought that didnt try yet is to connect an external usb disk with mac os and enable wol on that disk , and leave it connected in case of power failure
