I am very new to home assistant and i am not sure how to set up a switch that turns on my windows PC and get the status of that PC.
I have tried the following:
In configuration.yaml:
wake_on_lan:
I have then tried to add the following code in the configuration UI, manual code:
switch:
- platform: wake_on_lan
mac_address: "xx:xx:xx:xx:xx:xx"
host: "192.168.1.X"
broadcast_address: "192.168.1.255"
However i get a No card type error or SetConfig error. I have also tried adding it to the configuration.yaml but to no avail.
I must be missing something or doing something wrong but i have no idea what.
Kind regards
tom_l
June 17, 2020, 7:52am
2
Wrong place. That code goes in your configuration.yaml file under switch:. Also your indentation is incorrect. Should be:
switch:
host: "192.168.1.X"
So i now have my configuration.yaml as follows:
wake_on_lan:
switch:
host: "192.168.1.X"
I have rebooted and i get this error:
Invalid config
The following integrations and platforms could not be set up:
Please check your config.
Should the switch just automatically show up on my home assistant or do i have to add it somewhere…
Many thanks for your help
tom_l
June 17, 2020, 8:54am
4
Should be :
mac: "xx:xx:xx:xx:xx:xx"
Hi, sorry to bring an old subject back up. I manage to turn my PC on via a switch on HA but the switch does not show if the PC is on or off. As i flick the switch it toggles to on then after a few seconds it toggles back to off (even though the PC is on)
I have the following setup:
in my configutation.yaml
wake_on_lan:
In my switches.yaml
host: "192.168.1.40"
broadcast_address: "255.255.255.255"
How can i get the switch to check if the PC is on or off?
Any help appreciated
mcarty
(Arturo)
October 5, 2020, 11:18am
6
I am using the official addon RPC Shutdown, the Samba addon and this line:
mac: "xx-xx-xx-xx-xx-xx"
host: 192.168.0.124
turn_off:
service: hassio.addon_stdin
addon: core_rpc_shutdown
input: corei7
There is an explanation of all the steps somewhere in the docs.
Thanks for the response. I am not looking to shutdown the PC though, i simply want to get its status to hold on the switch that i have already.
I use a template switch for this:
switch:
switches:
pc:
friendly_name: PC
value_template: "{{ is_state('device_tracker.pc', 'home') }}"
icon_template: mdi:desktop-tower
turn_on:
service: wake_on_lan.send_magic_packet
mac: !secret computer_mac
broadcast_address: !secret fritzbox_broadcast
broadcast_port: 9
turn_off:
service: mqtt.publish
topic: "iotlink/workgroup/computer/commands/hibernate"
payload: ""
I use IOTLink for the state for my computer but you could use ping as well.
device_tracker:
- platform: ping
hosts:
pc: 192.168.2.100
Many thanks for your reply. I have tried to implement this but i cant get the switch to show up.
In my configuration.yaml i have the following:
switch: !include switches.yaml
And in the switches.yaml i have this:
- platform: mqtt
name: "Main House - General Heating"
command_topic: "cmnd/Tasmota_Sonoff_R3_Switch_1/power"
state_topic: "stat/Tasmota_Sonoff_R3_Switch_1/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- platform: mqtt
name: "Main House - Hot Water"
command_topic: "cmnd/Tasmota_Sonoff_R3_Switch_2/power"
state_topic: "stat/Tasmota_Sonoff_R3_Switch_2/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- platform: mqtt
command_topic: "cmnd/Tasmota_Sonoff_R3_Switch_3/power"
state_topic: "stat/Tasmota_Sonoff_R3_Switch_3/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- platform: mqtt
command_topic: "cmnd/Tasmota_Sonoff_R3_Switch_4/power"
state_topic: "stat/Tasmota_Sonoff_R3_Switch_4/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- platform: mqtt
command_topic: "cmnd/Tasmota_Sonoff_R3_Switch_5/power"
state_topic: "stat/Tasmota_Sonoff_R3_Switch_5/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
switch:
pc:
friendly_name: PC
value_template: '{{ is_state(''device_tracker.pc'', ''home'') }}'
icon_template: 'mdi:desktop-tower'
turn_on:
mac: 'xx:xx:xx:xx:xx:xx'
host: 192.168.1.xx
broadcast_address: 255.255.255.255
broadcast_port: 7`
device_tracker:
- platform: ping
scan_interval: 60
hosts:
pc: 192.168.1.XX
Any suggestions?
thiousi
(Thiousi)
January 4, 2022, 12:47pm
10
It seems your device_tracker is in our switches.yaml file. This would create an indentation issue. Maybe that’ll help?
I cannot make working the status check. The wake on lan integration contains text: " It’s required that the binary ping is in your $PATH ." which si not explained properly. Is this requirement related to the status check by adding the config variable “host”?
