Wake Up Alarm: Trigger Automation x minutes before input.datetime
I have set up a time only input.datetime helper with the time I wish my wake up alarm to be. I have also set up a input_number which ranges between 0 and 30 minutes. This is the time before the input.datetime that the automation should be triggered to start fading in my lights up to the wake up time. How would I go about using a template to trigger the automation the amount of time in the input_number before the input.datetime. Date is irellevant as it should run every day.
In other words I wish to trigger an automation a variable amount of time before a specific time both of which can be set in the frontend.
Create a Template Sensor that computes the wake up time (subtracts input_number’s value from the input_datetime’s value). Set its device_class to timestamp.
In your automation, use a Time Trigger that monitors the Template Sensor you created.
Simple as that; let me know if you need help creating the Template Sensor.
An alternative is to use a Template Trigger.
Thanks for your reply. I would prefer to use a template trigger to save any uneccesary entities I’m just not sure how to template it. I’m not familiar with templating timestamps.
Going from what you have already written:
    value_template: >
      {{  now() >= today_at(states('input_datetime.XXXX')) - timedelta(minutes= states('input_number.XXXX') | int) }}
I have tried this as per your suggestion:
{{ now() >= today_at('input_datetime.alarm_clock_time') - timedelta(minutes=states('input_number.alarm_clock_rise_time') | int) }}
but I get:
ValueError: could not convert str to datetime: 'input_datetime.alarm_clock_time’
and removing the apostrophes:
{{ now() >= today_at(input_datetime.alarm_clock_time) - timedelta(minutes=states('input_number.alarm_clock_rise_time') | int) }}
gives:
UndefinedError: ‘input_datetime’ is undefined
Sorry for the typo, see original post for correction.
Thanks! This appears to work correctly. Now i just need a way to pass the input_number.alarm_clock_rise_time to the scene.turn_on service.
My action for the automation is:
service: scene.turn_on
  transition: 60
  entity_id: scene.standard
And the transition entry needs to take the value of the input number. Any ideas? Thanks!
I don’t know for certain if transition supports templating. If it does then this should work.
  transition: "{{ states('input_number.alarm_clock_rise_time') | int(0) }}"
This does appear to be supported (it is working) however the transistion is in seconds and my value is in minutes so i changed it to the following for the reference of anyone viewing this thread in future.
  transition: '{{ states(''input_number.alarm_clock_rise_time'') | int(0) * 60 }}'
  entity_id: scene.wake_up_alarm
The complete automation looks like:
alias: Wake Up Alarm
description: ''
    value_template: >-
      {{  now() >= today_at(states('input_datetime.alarm_clock_time')) -
      timedelta(minutes= states('input_number.alarm_clock_rise_time') | int) }}
  - platform: time
    at: input_datetime.alarm_clock_time
  - platform: state
    entity_id: binary_sensor.iphone_focus
    to: 'off'
condition: []
  - choose:
      - conditions:
          - condition: trigger
          - condition: state
            entity_id: input_boolean.alarm_clock_active
            state: 'on'
        sequence:
          - service: scene.turn_on
      - conditions:
          - condition: state
            state: 'on'
        sequence:
          - service: notify.mobile_app_iphone
              title: Alarm Clock
              message: It's time to wake up!
      - conditions:
          - condition: state
            entity_id: device_tracker.iphone
            state: home
        sequence:
              transition: 10
    default: []
mode: single
Since I was looking for similar automation could you pls help with mine? I have a time sensor that dynamically changes let’s say sensor.sunset_time. I want to set an automation that will notify me 10 minutes before the sunset. How can I achieve that?
You could probably just change
to
sensor.sunset_time
I am trying to do something similar, but I cannot get the automation to trigger with
  • platform: time
it only works if I use
  • platform: time
    at: ‘06:00:00’
I have the input.datetime defined as time only.
Any thoughts or suggestions are appreciated.
A Time Trigger supports an input_datetime that includes time-only, date-only, or time and date. If it’s not working for your time-only input_datetime then the question is: are you using a very old version of Home Assistant?
If you are using a recent version, then check the automation’s trace to see if it has in fact triggered but encountered some other problem.
Thank you very much for responding! I am running version 2022.7.7. I checked the trace for the automation but since it doesn’t trigger I don’t get anything.
# Inputdatetime
 alert_reminder_1:
    has_time: true
    has_date: false
 alert_reminder_2:
    has_time: true
    has_date: false
# automation
- alias: Alert Reminder
  initial_state: True
    - platform: time
      at: 'input_datetime.alarm_clock_time'
    - platform: time
      at: 'input_datetime.alarm_clock_time2'
    service: input_boolean.turn_on
    data: {}
      entity_id: input_boolean.reminder_alert
I believe the reason why your automation isn’t triggering is because its two Time Triggers refer to input_datetime entities that don’t exist.
When you define an input_datetime, the name option represents its friendly name not its entity_id. The Time Trigger requires the input_datetime’s entity_id.
Here’s how to correctly reference the two input_datetime entities that you defined:
    - platform: time
      at: 'input_datetime.alert_reminder_1'
    - platform: time
      at: 'input_datetime.alert_reminder_2'
You can also do this:
    - platform: time
      at:
        - input_datetime.alert_reminder_1
        - input_datetime.alert_reminder_2
That was exactly it! I am embarrassed I did not catch that. I really appreciate your help! Thank you!
