The automation is triggered by a state change of the sensor.wekker_minus_10_minutes
First turn on the rgb light with a red color and low brightness.
Then repeat a sequence of actions 30 times, each time increasing the brightness and changing the color of the light. This creates the gradual wake-up effect.
Add a delay of 20 seconds after the final step of the sequence. This is to ensure that the light remains on for a little while after it has reached maximum brightness.
Overall, this automation must simulates a sunrise by gradually increasing the brightness and changing the color of a light entity over a period of 30 minutes, starting from a low red color and ending with a bright, warm white color.
But the automation stops for me at 14% on a green light. what am I not doing quite right yet?
I see, i have set the count not good. and that is right it is jungle green instead of warm white color. I hadn’t thought that I can check it in the template editor
Are you using ChatGPT to produce this, or randomly copy/pasting stuff that looks similar to what you want? There’s no way you could have written that script above thinking that it would do that.
Paste the latest status of your script and describe exactly what you want it to do.
