Hi everyone,
I configured two binary sensors on ESP32 D1 Mini:
binary_sensor:
- platform: gpio
pin:
number: 4
allow_other_uses: true
mode:
input: True
pullup: True
- platform: gpio
pin:
number: 33
mode:
input: True
pullup: True
inverted: True
Both of them work as expected. When the ‘door_sensor’ is open, alarm rings. When ‘test_alarm’ button is pressed, the buzzer goes off for a second. The problem is, I cannot use both of them for waking up from a deep sleep.
deep_sleep:
run_duration: 30sec
sleep_duration: 3min
esp32_ext1_wakeup:
pins:
number: 4
allow_other_uses: True
number: 33
inverted: True
mode: INPUT_PULLUP
mode: ANY_HIGH
Pin 4 is LOW by default, and PIN 33 is HIGH. The former wakes up from a deep sleep well. But the latter wakes up instantly after going to a deep sleep since it is HIGH when the button is not pressed. Stuck here. How can I use pin 33 to wake up properly when pressed?
