Wall light switch suggestions (8mm installation pitch)
Hey guys,
I’m looking for a wall light switch something like this:
Problem is my wall outlets installation pitch (distance between the screws) is 8mm (not 6, which seems to be the standard I see for
just about everything).
I also do not have a Neutral wire running through my outlets…
Any suggestions ? :slight_smile:
The Fibaro switch or dimmer should work. They don’t need a neutral wire.
Interesting… will take a look, thanks!
