<li data-row="5" data-col="1" data-sizex="2" data-sizey="1">
<div data-id="camera1" data-view="cameras" data-title="CAM" </div>
</li>
this is how i made the config… But i Fail of course.
</li>
Have you got your camera working in HASS yet? You have to go to the states page on hass then find the camera entity, you will see something like this /api/camera_proxy/camera.name?token=1234567890, copy it and replace the sample in jobs/cameras.rb - the bold section in that line
@camera1_api_url = “/api/camera_proxy/camera.name?token=1234567890&api_password=#{ha_key}”
Make sure you remove all other code for extra camera in cameras.rb if you have less than 4 cameras.
Post your code here if you still have trouble getting it to work, happy to help.
require 'net/http'
require "uri"
@cameraDelay = 1 # Needed for image sync.
@fetchNewImageEvery = '1s' # replace new image every 10secs, change to whatever refresh time you want
@ha_host = "192.168.1.22" # your hass ip
@ha_port = "8123" # hass port
ha_key = "" # hass api key
@camera1_api_url = "/api/camera_proxy/camera.emevth_security_cam?token=1827471472&api_password=#{ha_key}" # get your camera1 api url from hass entity page
@newFile1 = "assets/images/cameras/snapshot1_new.jpg"
@oldFile1 = "assets/images/cameras/snapshot1_old.jpg"
def fetch_image_http(host,old_file,new_file, cam_port, cam_url)
`rm #{old_file}`
`mv #{new_file} #{old_file}`
Net::HTTP.start(host,cam_port) do |http|
req = Net::HTTP::Get.new(cam_url)
response = http.request(req)
open(new_file, "wb") do |file|
file.write(response.body)
end
end
new_file
end
def fetch_image_https(host,old_file,new_file, cam_port, cam_url)
`rm #{old_file}`
uri = URI('https://...')
Net::HTTP.start(host,cam_port,
:use_ssl => uri.scheme == 'https',
:verify_mode => OpenSSL::SSL::VERIFY_NONE) do |http|
end
end
new_file
end
def make_web_friendly(file)
"/" + File.basename(File.dirname(file)) + "/" + File.basename(file)
end
SCHEDULER.every @fetchNewImageEvery, first_in: 0 do
new_file1 = fetch_image_http(@ha_host,@oldFile1,@newFile1,@ha_port,@camera1_api_url) # change fetch_image_https to fetch_image_http if you use hass without ssl
new_file2 = fetch_image_https(@ha_host,@oldFile2,@newFile2,@ha_port,@camera2_api_url) # change fetch_image_https to fetch_image_http if you use hass without ssl
new_file3 = fetch_image_https(@ha_host,@oldFile3,@newFile3,@ha_port,@camera3_api_url) # change fetch_image_https to fetch_image_http if you use hass without ssl
new_file4 = fetch_image_https(@ha_host,@oldFile4,@newFile4,@ha_port,@camera4_api_url) # change fetch_image_https to fetch_image_http if you use hass without ssl
if not File::exists?(@newFile1 && @newFile2 && @newFile3 && @newFile4) # add/remove according to the number of camera needed
warn "Failed to Get Camera Image"
end
send_event('camera1', image: make_web_friendly(@oldFile1))
sleep(@cameraDelay)
send_event('camera1', image: make_web_friendly(new_file1))
end
this is how my camrea.rb looks like… how do i now have to put this in hadashboard?
this is my config in hadash:
<li data-row="1" data-col="2" data-sizex="2" data-sizey="2">
<div data-id="emevth_security_cam" data-view="camera1" data-title="Front Cam">
</div>
</li>
remove these lines
and
&& @newFile2 && @newFile3 && @newFile4 so it read if not File::exists?(@newFile1)
if you don’t use password for hass, try to remove this part as well “&api_password=#{ha_key}”, I haven’t try it without password.
<li data-row="6" data-col="2" data-sizex="2" data-sizey="2">
</div>
</li>
pi@Home-Assistant:~/hadashboard/jobs $ cat cameras.rb
require 'net/http'
require "uri"
@camera1_api_url = "/api/camera_proxy/camera.emevth_security_cam?token=1827471472" # get your camera1 api url from hass entity page
`rm #{old_file}`
end
end
new_file
end
`rm #{old_file}`
end
end
new_file
end
end
if not File::exists?(@newFile1 ) # add/remove according to the number of camera needed
end
sleep(@cameraDelay)
end
How can I do a location.reload or something similar for refresh all page?
Thanks!
There’s a widget for it in example.erb, is it something like that you mean?
You put
data-id="reload" data-view="Reload"
in your div tag for it to show up.
Hi i really like the Dashboard! I just installed it today.
However i’m running in some problems. I adjusted the main.erb to only show time and a switch for now.
When i push the switch it will take around 8 minutes to turn it on or off. it throw some errors:
2016-10-30 15:45:23 - Net::ReadTimeout - Net::ReadTimeout:
/usr/lib/ruby/2.1.0/net/protocol.rb:158:in `rescue in rbuf_fill'
/usr/lib/ruby/2.1.0/net/protocol.rb:152:in `rbuf_fill'
/usr/lib/ruby/2.1.0/net/protocol.rb:134:in `readuntil'
/usr/lib/ruby/2.1.0/net/protocol.rb:144:in `readline'
/usr/lib/ruby/2.1.0/net/http/response.rb:39:in `read_status_line'
/usr/lib/ruby/2.1.0/net/http/response.rb:28:in `read_new'
/usr/lib/ruby/2.1.0/net/http.rb:1408:in `block in transport_request'
/usr/lib/ruby/2.1.0/net/http.rb:1405:in `catch'
/usr/lib/ruby/2.1.0/net/http.rb:1405:in `transport_request'
/usr/lib/ruby/2.1.0/net/http.rb:1378:in `request'
/usr/lib/ruby/2.1.0/net/http.rb:1371:in `block in request'
/usr/lib/ruby/2.1.0/net/http.rb:853:in `start'
/usr/lib/ruby/2.1.0/net/http.rb:1369:in `request'
/home/pi/hadashboard/jobs/homeassistant.rb:23:in `ha_api'
/home/pi/hadashboard/jobs/homeassistant.rb:45:in `block in <top (required)>'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1611:in `call'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1611:in `block in compile!'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:975:in `[]'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:975:in `block (3 levels) in route!'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:994:in `route_eval'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:975:in `block (2 levels) in route!'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1015:in `block in process_route'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1013:in `catch'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1013:in `process_route'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:973:in `block in route!'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:972:in `each'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:972:in `route!'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1085:in `block in dispatch!'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1067:in `block in invoke'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1067:in `catch'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1067:in `invoke'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1082:in `dispatch!'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:907:in `block in call!'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:907:in `call!'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:895:in `call'
/var/lib/gems/2.1.0/gems/rack-protection-1.5.3/lib/rack/protection/xss_header.rb:18:in `call'
/var/lib/gems/2.1.0/gems/rack-protection-1.5.3/lib/rack/protection/path_traversal.rb:16:in `call'
/var/lib/gems/2.1.0/gems/rack-protection-1.5.3/lib/rack/protection/json_csrf.rb:18:in `call'
/var/lib/gems/2.1.0/gems/rack-protection-1.5.3/lib/rack/protection/base.rb:49:in `call'
/var/lib/gems/2.1.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/logger.rb:15:in `call'
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/commonlogger.rb:33:in `call'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:219:in `call'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:212:in `call'
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/head.rb:11:in `call'
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/methodoverride.rb:21:in `call'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/show_exceptions.rb:25:in `call'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:182:in `call'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:2013:in `call'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1487:in `block in call'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1787:in `synchronize'
/var/lib/gems/2.1.0/gems/sinatra-1.4.7/lib/sinatra/base.rb:1487:in `call'
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/urlmap.rb:65:in `block in call'
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/urlmap.rb:50:in `each'
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/urlmap.rb:50:in `call'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:86:in `block in pre_process'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:84:in `catch'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:84:in `pre_process'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:53:in `process'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:39:in `receive_data'
/var/lib/gems/2.1.0/gems/eventmachine-1.2.0.1/lib/eventmachine.rb:194:in `run_machine'
/var/lib/gems/2.1.0/gems/eventmachine-1.2.0.1/lib/eventmachine.rb:194:in `run'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/backends/base.rb:73:in `start'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/server.rb:162:in `start'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/controllers/controller.rb:87:in `start'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/runner.rb:200:in `run_command'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/runner.rb:156:in `run!'
/var/lib/gems/2.1.0/gems/thin-1.6.4/bin/thin:6:in `<top (required)>'
/usr/local/bin/thin:23:in `load'
/usr/local/bin/thin:23:in `<top (required)>'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/cli/exec.rb:74:in `load'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/cli/exec.rb:74:in `kernel_load'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/cli/exec.rb:27:in `run'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/cli.rb:332:in `exec'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/vendor/thor/lib/thor.rb:359:in `dispatch'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/cli.rb:20:in `dispatch'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/vendor/thor/lib/thor/base.rb:440:in `start'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/cli.rb:11:in `start'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/exe/bundle:34:in `block in <top (required)>'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/lib/bundler/friendly_errors.rb:100:in `with_friendly_errors'
/var/lib/gems/2.1.0/gems/bundler-1.13.6/exe/bundle:26:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
192.168.1.8 - - [30/Oct/2016 15:45:24] "GET /events?lastEventId=&r=6179000933000782 HTTP/1.1" 200 - 240.5259
scheduler caught exception:
Net::ReadTimeout
/home/pi/hadashboard/jobs/homeassistant.rb:282:in `block in <top (required)>'
/var/lib/gems/2.1.0/gems/rufus-scheduler-2.0.24/lib/rufus/sc/jobs.rb:230:in `call'
/var/lib/gems/2.1.0/gems/rufus-scheduler-2.0.24/lib/rufus/sc/jobs.rb:230:in `trigger_block'
/var/lib/gems/2.1.0/gems/rufus-scheduler-2.0.24/lib/rufus/sc/jobs.rb:204:in `block in trigger'
/var/lib/gems/2.1.0/gems/rufus-scheduler-2.0.24/lib/rufus/sc/scheduler.rb:430:in `call'
/var/lib/gems/2.1.0/gems/rufus-scheduler-2.0.24/lib/rufus/sc/scheduler.rb:430:in `block in trigger_job'
I’m running Hadashboard on an rpi 2 with raspbian jessie and i used the manual installation method.
I have adjusted ha_conf.rb to:
$ha_url = “https://myname.duckdns.org:443”
$ha_apikey = “mypassword”
Maybe somebody can see what i did wrong or need to do?
Thanks in advance!
You shouldn’t need the port here.
Thanks for your response i removed the :443. But now i can’t start it somehow.
pi@raspberrypi:~/hadashboard $ dashing start
bundler: failed to load command: thin (/usr/local/bin/thin)
NoMethodError: undefined method `each' for nil:NilClass
/home/pi/hadashboard/jobs/news.rb:56:in `<top (required)>'
/var/lib/gems/2.1.0/gems/backports-3.6.8/lib/backports/std_lib.rb:9:in `require'
/var/lib/gems/2.1.0/gems/backports-3.6.8/lib/backports/std_lib.rb:9:in `require_with_backports'
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:171:in `block in require_glob'
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:170:in `each'
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:170:in `require_glob'
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:181:in `<top (required)>'
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing.rb:3:in `require'
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing.rb:3:in `<top (required)>'
config.ru:1:in `require'
config.ru:1:in `block in <main>'
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/builder.rb:55:in `instance_eval'
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/builder.rb:55:in `initialize'
config.ru:1:in `new'
config.ru:1:in `<main>'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/rack/adapter/loader.rb:33:in `eval'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/rack/adapter/loader.rb:33:in `load'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/controllers/controller.rb:182:in `load_rackup_config'
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/controllers/controller.rb:72:in `start'
and i installed thin after this but it gives the same error.
sudo gem install thin
Building native extensions. This could take a while...
Successfully installed thin-1.7.0
Parsing documentation for thin-1.7.0
Done installing documentation for thin after 7 seconds
1 gem installed
EDIT: The not starting was caused by me deleting:
$news_feeds = {
“Traffic” => “http://api.sr.se/api/rss/traffic/2863”,
“News” => “http://feeds.bbci.co.uk/news/rss.xml”,
I think the problem is in your ha_conf.rb
file - what do you have set for your newsfeeds?
oh i just edited my post. i deleted that when removing de 443 part.
it now started.
Thin web server (v1.6.4 codename Gob Bluth)
Maximum connections set to 1024
Listening on 0.0.0.0:3030, CTRL+C to stop
192.168.1.8 - - [30/Oct/2016 18:25:38] "GET /main HTTP/1.1" 200 1689 0.0423
192.168.1.8 - - [30/Oct/2016 18:26:49] "GET /views/clock.html HTTP/1.1" 200 66 0.0070
192.168.1.8 - - [30/Oct/2016 18:26:49] "GET /views/haswitch.html HTTP/1.1" 200 130 0.0057
Net::ReadTimeout
but now i get the same error as before removing the 443 part.
now this is my ha_conf.rb:
$ha_url = "https://myname.duckdns.org"
$ha_apikey = "mypassword"
$news_feeds = {
"Traffic" => "http://api.sr.se/api/rss/traffic/2863",
"News" => "http://feeds.bbci.co.uk/news/rss.xml",
OK, the problem now is that the dashboard can’t speak to homeassistant - have you verified that URL works in a browser? FWIW, in my setup, with SSL, I just use the IP address and port not the whole dynamic DNS name, e.g. https://192.168.1.20:8123
and it works fine.
That could be my problem, because i can’t use something like https://192.168.1.20:8123 since i did set-up ssl.
But it does somehow talk to hass trough my url, because after like 8 minutes the switch is turned on or off?
can maybe someone help me to setup the cam widged?
That should work for SSL as well - I have SSL with letsencrypt and it works fine for me.
Thank you for your help. i’m using lets encrypt aswell. The problem is not with hadashboard. I removed the port forwarding from 443 to 8123 and i can acces it via this
And hadashboard is working fine. So i think i need to do some searching, because now i can’t use ssl and hadashboard at same time.
EDIT: I don’t know what did happen, but it is working now.
EDIT2: It happens to be a function of my netgear wndr4500 router which is called something like external control. After disabling it everything works perfect. I can finally start configuring the dashboard. Thanks for the help.
EDIT 3: Problem still Exist somehow it works for some periods off time, mostly when i change a setting in de router and it updates then the problem goes away for some time.
Hey guys. I was looking around to find maybee another nice dashing theme and found this: https://github.com/Aricwithana/LCARS-SDK do you think it is possible to integrate this in hadashboard?
@thundergreen this is what i have.
require 'net/http'
require "uri"
@ha_host = "192.168.1.55" # your hass ip
ha_key = "mypass" # hass api key
@camera1_api_url = "/api/camera_proxy/camera.tuin?token=1831727640&api_password=#{ha_key}" # get your camera1 api url from hass entity page
`rm #{old_file}`
end
end
new_file
end
`rm #{old_file}`
end
end
new_file
end
end
new_file1 = fetch_image_https(@ha_host,@oldFile1,@newFile1,@ha_port,@camera1_api_url) # change fetch_image_https to fetch_image_http if you use hass without ssl
if not File::exists?(@newFile1) #removed # && @newFile2 && @newFile3 && @newFile4 ##add/remove according to the number of camera needed
end
sleep(@cameraDelay)
end
and in main.erb:
<div class="gridster"> <!-- Panel - PAGE 2 -->
<ul>
<li data-row="5" data-col="1" data-sizex="3" data-sizey="3">
<div data-id="camera1" data-view="Cameras" data-title="tuin" ></div>
</li>
<li data-row="1" data-col="1" data-sizex="1" data-sizey="1">
<div data-id="cpage1" data-view="ChangePage" data-icon="cogs" data-title="Main panel" data-page="1" data-stagger="false" data-fasttransition="true" data-event-click="onClick"></div>
</li>
<li data-row="6" data-col="8" data-sizex="1" data-sizey="1">
<div data-id="reload" data-view="Reload"></div>
</li>
</div>
But this gives me only an image when i reload the dashboard. It is not automatic updating. Is that how it is supposed to work?
