That’s just sudo again - says you don;t have perms to do the install.
How do i add more news feeds?
Like this:
“News” => “news1”, “news 2”, “news3” ?
No, each one needs a complete line like the two already in there:
“news 1” => “Feed path 1”,
“news 2” => “Feed path 2”,
“news 3” => “Feed path 3”,
Then you need to reference “news 1”, "news 2 etc. from the widget you want to display them.
So I’m now running the full version of linux raspian. I got the git command to work, and then went into the hadashboard folder. From there I did the gem install dashing command. Had to put sudo in front of it, but this is the output:
(homeassistant_venv) pi@raspberrypi:~/hadashboard $ sudo gem install dashing
Fetching: sass-3.2.19.gem (100%)
Successfully installed sass-3.2.19
Fetching: coffee-script-source-1.11.1.gem (100%)
Successfully installed coffee-script-source-1.11.1
Fetching: execjs-2.0.2.gem (100%)
Successfully installed execjs-2.0.2
Fetching: coffee-script-2.2.0.gem (100%)
Successfully installed coffee-script-2.2.0
Fetching: rack-1.5.5.gem (100%)
Successfully installed rack-1.5.5
Fetching: rack-protection-1.5.3.gem (100%)
Successfully installed rack-protection-1.5.3
Fetching: tilt-1.4.1.gem (100%)
Successfully installed tilt-1.4.1
Fetching: sinatra-1.4.7.gem (100%)
Successfully installed sinatra-1.4.7
Fetching: multi_json-1.12.1.gem (100%)
Successfully installed multi_json-1.12.1
Fetching: rack-test-0.6.3.gem (100%)
Successfully installed rack-test-0.6.3
Fetching: backports-3.6.8.gem (100%)
Successfully installed backports-3.6.8
Fetching: sinatra-contrib-1.4.7.gem (100%)
Successfully installed sinatra-contrib-1.4.7
Fetching: daemons-1.2.4.gem (100%)
Successfully installed daemons-1.2.4
Fetching: eventmachine-1.2.1.gem (100%)
Building native extensions. This could take a while…
ERROR: Error installing dashing:
ERROR: Failed to build gem native extension.
/usr/bin/ruby2.1 extconf.rb
mkmf.rb can’t find header files for ruby at /usr/lib/ruby/include/ruby.h
extconf failed, exit code 1
Gem files will remain installed in /var/lib/gems/2.1.0/gems/eventmachine-1.2.1 for inspection.
Results logged to /var/lib/gems/2.1.0/extensions/arm-linux/2.1.0/eventmachine-1.2.1/gem_make.out
(homeassistant_venv) pi@raspberrypi:~/hadashboard $ /usr/bin/ruby2.1 extconf.rb
/usr/bin/ruby2.1: No such file or directory – extconf.rb (LoadError)
(homeassistant_venv) pi@raspberrypi:~/hadashboard $ mkmf.rb can’t find header files for ruby at /usr/lib/ruby/include/ruby.h
Seems like I’m still getting an error and not sure why.
EDIT; Seems I might have figured things out. I went ahead in the directions and just starting installing things that needed to be installed. Finally got to this list:
ruby-dev - sudo apt-get install ruby-dev
node-js - sudo apt-get install nodejs
execjs gem - gem install execjs
And that seemed to help.
I’m leaving my last post to hopefully help some people, but I’m up against a new issue. I’m attempting to do the bundle command, and it seems to work, until the end. Here is the result of doing the bundle command:
(homeassistant_venv) pi@raspberrypi:~/hadashboard $ bundle
Fetching gem metadata from https://rubygems.org/…
Fetching version metadata from https://rubygems.org/…
Fetching dependency metadata from https://rubygems.org/.
Resolving dependencies…
Using addressable 2.3.8
Using backports 3.6.8
Using bcrypt 3.1.11
Using coffee-script-source 1.11.1
Using execjs 2.0.2
Using daemons 1.2.4
Using rack 1.5.5
Using thread_safe 0.3.5
Using sass 3.2.19
Using tilt 1.4.1
Using multi_json 1.12.1
Using hike 1.2.3
Using eventmachine 1.2.1
Using thor 0.19.4
Using fastercsv 1.5.5
Using json 1.8.3
Using json_pure 1.8.3
Using stringex 1.5.1
Using uuidtools 2.1.5
Using htmlentities 4.3.4
Using mime-types 1.25.1
Using mini_portile2 2.1.0
Using bundler 1.13.6
Using dm-core 1.2.1
Using data_objects 0.10.17
Using bcrypt-ruby 3.1.5
Using coffee-script 2.2.0
Using rack-protection 1.5.3
Using rack-test 0.6.3
Using tzinfo 1.2.2
Using sprockets 2.10.2
Using thin 1.6.4
Using rest-client 1.6.9
Using nokogiri 1.6.8.1
Using dm-aggregates 1.2.0
Using dm-constraints 1.2.0
Using dm-migrations 1.2.0
Using dm-serializer 1.2.2
Using dm-timestamps 1.2.0
Using dm-transactions 1.2.0
Using dm-validations 1.2.0
Using dm-do-adapter 1.2.0
Installing do_sqlite3 0.10.17 with native extensions
Using dm-types 1.2.2
Using sinatra 1.4.7
Using rufus-scheduler 2.0.24
Using unirest 1.1.2
Gem::Ext::BuildError: ERROR: Failed to build gem native extension.
checking for sqlite3.h… no
*** extconf.rb failed ***
Could not create Makefile due to some reason, probably lack of necessary
libraries and/or headers. Check the mkmf.log file for more details. You may
need configuration options.
Provided configuration options:
–with-opt-dir
–without-opt-dir
–with-opt-include
–without-opt-include=${opt-dir}/include
–with-opt-lib
–without-opt-lib=${opt-dir}/lib
–with-make-prog
–without-make-prog
–srcdir=.
–curdir
–ruby=/usr/bin/ruby2.1
–with-sqlite3-dir
–without-sqlite3-dir
–with-sqlite3-include
–without-sqlite3-include=${sqlite3-dir}/include
–with-sqlite3-lib
–without-sqlite3-lib=${sqlite3-dir}/lib
/tmp/bundler20161207-22136-oswmxmdo_sqlite3-0.10.17/gems/do_sqlite3-0.10.17 for
inspection.
Results logged to
/tmp/bundler20161207-22136-oswmxmdo_sqlite3-0.10.17/extensions/arm-linux/2.1.0/do_sqlite3-0.10.17/gem_make.out
An error occurred while installing do_sqlite3 (0.10.17), and Bundler
cannot continue.
Make sure that gem install do_sqlite3 -v '0.10.17'
succeeds before
bundling.
Any help would be appreciated.
EDIT: Just did a sudo apt-get install libsqlite3-dev and then retried bundle and it went through.
Thanks for the answer.
I’m also have difficulties finding the autostart script in the hadashboard/init folder, what is it called? Proberbly just me looking in a wrong folder or something
So I have figured it all out! Now I just need to learn how to edit the file to use my own information and such, but I’ll save that for another night. Thanks for all the help here. I feel like I cluttered the thread for a bit, but I hope that my experiences will be helpful to others.
Thanks!! That’s the bit I was missing
So I am really liking this project. I was able to add a component and everything, which is pretty good for me, given that a lot of this is brand new.
Now though, I’m having trouble with News and RSS feeds. For the life of me, I can’t figure out what I’m doing wrong.
Any help would be appreciated. Whatever I do, all I get are two widgets, one that says CNN and one that says technology.
Edit: turns out I just had to close down the terminal running the dashboard and restart it and that made the news feeds work
Also one other quick question I set it up using the manual instructions on my Raspberry Pi so I think that means I do not have Docker setup for Docker widget is that something that I should get set up anyway? Or will I still be able to use docker widgets without having to setting up?
a quote i picked up somewhere:
If you’re not already familiar with Docker, it’s a method of packaging software to include not only your code, but also other components such as a full file system, system tools, services, and libraries
so if everything is like it should, there should not be other widgets in the docker files then in the manual installations.
I get this message on a raspberry pi 2:
Fetching dependency metadata from https://rubygems.org/…
Rubygems 1.8.24 is not threadsafe, so your gems will be installed one at a time. Upgrade to Rubygems 2.1.0 or higher to enable parallel gem installation.
Installing addressable 2.3.8
Installing bcrypt 3.1.11 with native extensions
Using execjs 2.0.2
Using daemons 1.2.4
Using rack 1.5.5
Using sass 3.2.19
Using tilt 1.4.1
Using hike 1.2.3
Using thor 0.19.4
Installing fastercsv 1.5.5
Installing json 1.8.3 with native extensions
Installing json_pure 1.8.3
Installing stringex 1.5.1
Installing uuidtools 2.1.5
Installing htmlentities 4.3.4
Installing mime-types 1.25.1
Installing mini_portile2 2.1.0
Installing dm-core 1.2.1
Installing data_objects 0.10.17
Installing bcrypt-ruby 3.1.5
Using tzinfo 1.2.2
Using thin 1.6.4
Installing rest-client 1.6.9
Gem::InstallError: mini_portile2 requires Ruby version >= 1.9.2.
An error occurred while installing mini_portile2 (2.1.0), and Bundler cannot continue.
Make sure that gem install mini_portile2 -v '2.1.0'
succeeds before bundling.
pi@raspberrypi:~/hadashboard $ ^C
I’ve installed the latest Ruby
I had errors left and right as well, but I went through and installed all these. Then it worked. Not sure if that will help out even if you still need to install them but it’s worth a try.
the error shows that you have rubygems 1.8.24 installed and that there is al least a version 2.1.0
so when you installed ruby it probably wasnt the latest.
upgrading ruby could solve your problem.
I installed this first:
pi@raspberrypi:~/hadashboard $ sudo apt-get install ruby
Pakketlijsten worden ingelezen… Klaar
Boom van vereisten wordt opgebouwd
De statusinformatie wordt gelezen… Klaar
De volgende extra pakketten zullen geïnstalleerd worden:
ruby2.1 rubygems-integration
Voorgestelde pakketten:
ri bundler
De volgende NIEUWE pakketten zullen geïnstalleerd worden:
ruby ruby2.1 rubygems-integration
0 opgewaardeerd, 3 nieuw geïnstalleerd, 0 te verwijderen en 1 niet opgewaardeerd.
Er moeten 290 kB aan archieven opgehaald worden.
I also checked:
pi@raspberrypi:~/hadashboard $ sudo apt-get install rubygems
rubygems is reeds de nieuwste versie.
and still the same outcome
Thanks, I did this series again with no success on Bundle
did you get the same error?
Yes the same
mini_portile2-2.1.0 requires ruby version >= 1.9.2, which is incompatible with the current version, ruby 1.8.7p358
so it really seems that you dont have the latest ruby version installed.
Shoot. Sorry I can’t help more. Good luck!
