Yes, I was thinking the same - it causes a lot of issues so I will see about making it optional.
I have my front end customised so the are not displayed unless I specify the sensor in my groups.yaml
Hi. I have now made a fresh install of hass on my RPI with the RPI image. I have installed HADashboard, but when trying to start dashing i only see a black example screen.
This is what putty tells me:
pi@raspberrypi:~/hadashboard $ dashing start
Thin web server (v1.6.4 codename Gob Bluth)
Maximum connections set to 1024
Listening on 0.0.0.0:3030, CTRL+C to stop
192.168.0.16 - - [16/Dec/2016 15:38:59] âGET / HTTP/1.1â 302 - 0.0073
192.168.0.16 - - [16/Dec/2016 15:38:59] âGET /example HTTP/1.1â 200 12495 0.0349
192.168.0.16 - - [16/Dec/2016 15:40:00] âGET /example HTTP/1.1â 200 12495 0.0682
192.168.0.16 - - [16/Dec/2016 15:40:03] âGET /example HTTP/1.1â 200 12495 0.0781
^C/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/cli.rb:89:in system': Interrupt from /var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/cli.rb:89:in
run_commandâ
from /var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/cli.rb:64:in start' from /var/lib/gems/2.1.0/gems/thor-0.19.4/lib/thor/command.rb:27:in
runâ
from /var/lib/gems/2.1.0/gems/thor-0.19.4/lib/thor/invocation.rb:126:in invoke_command' from /var/lib/gems/2.1.0/gems/thor-0.19.4/lib/thor.rb:369:in
dispatchâ
from /var/lib/gems/2.1.0/gems/thor-0.19.4/lib/thor/base.rb:444:in start' from /var/lib/gems/2.1.0/gems/dashing-1.3.7/bin/dashing:9:in
<top (required)>â
from /usr/local/bin/dashing:23:in load' from /usr/local/bin/dashing:23:in
â
pi@raspberrypi:~/hadashboard $ Stopping âŚ
^C
Anyone know what i need to do?
Nevermind. Did
pi@raspberrypi:~$ sudo gem install execjs
pi@raspberrypi:~$ sudo apt-get install nodejs
It fixed the problem
But now i have this problem when triyng to get the reboot working
pi@raspberrypi:~ $ sudo update-rc.d dashboard defaults
insserv: warning: script âdashboardâ missing LSB tags and overrides
insserv: script dashing: service dashboard already provided!
Anyone know what to do?
The dashboard file is empty, should it be that? Guide says nothing
EDIT: Iâve edited the entire post with the working config of getting both Dashing and hapush to run at boot
DASHING CONFIG
Here is what I believe is the correct config to get dashing to boot at start for anyone struggling with it.
pi@host:~ $ sudo cp hadashboard/init/dashing /etc/init.d
pi@host:~ $ sudo nano /etc/init.d/dashing
Amend the DASHING_DIR to point to your dashing location
NAME=dashing
DASHING_DIR=/home/pi/hadashboard
DAEMON=/usr/local/bin/dashing
PIDFILE=â$DASHING_DIR/$NAME.pidâ
DAEMON_OPTS=âstart -d -P $PIDFILEâ
GEM_HOME=/usr/local/lib/ruby/gems/1.9.1
Then run the following commands
pi@host:~ $ sudo chmod 755 /etc/init.d/dashing
pi@host:~ $ sudo systemctl enable /home/pi/hadashboard/init/dashing.service
pi@host:~ $ sudo update-rc.d dashing defaults
pi@host:~ $ sudo reboot
HAPUSH CONFIG
Ensure you have the logs folder and hapush.log created and in your file system. The logging location is configured in /hadashboard/hapush/hapush.cfg
ha_url = âhttps://subdomain.domain.com:8123â
ha_key = API_KEY_HERE
dash_host = â192.168.1.7:3030â
dash_dir = â/home/pi/hadashboard/dashboardsâ
logfile = â/home/pi/logs/hapush.logâ
> pi@host:~ $ sudo cp hadashboard/init/hapush /etc/init.d
> pi@host:~ $ sudo nano /etc/init.d/hapush
NAME=hapush
HAPUSH_DIR=/home/pi/hadashboard/hapush
DAEMON=â$HAPUSH_DIR/$NAME.pyâ
PIDFILE=â$HAPUSH_DIR/$NAME.pidâ
CFGFILE=â$HAPUSH_DIR/$NAME.cfgâ
DAEMON_OPTS=â-d -p $PIDFILE $CFGFILEâ
pi@host:~ $ sudo chmod 755 /etc/init.d/hapush pi@host:~ $ sudo systemctl enable /home/pi/hadashboard/init/hapush.service pi@host:~ $ sudo update-rc.d hapush defaults pi@host:~ $ sudo reboot
You should now have Dashing and hapush start on boot, you can check the hapush logs in the logs folder that you set earlier
This dashboard looks great, but I found another dashboard which is really nice and have quite a lot of widgets. Have a look here.
This is a thread about this dashboard - feel free to talk about other dashboards in a separate thread so people donât get confused.
Thank you for this guide, gonna try it as soon as i have time.
But why do i need to nano that dashing file when I donât write anything in it, itâs just an empty file. Or am I missing something?
@perevers Youâll copy (cp) the dashing script from hadashboard/init to /etc/init.d/ using the first command (shown below for your refeerence)
and then you will edit it as shown in the guide above
Sory for that. What I really wonder is if it could improve Hadashboard or could be ported somehow. Take the number of widgets for example FHEM Tablet UI has 35+
there could be taken some ideas from it.
the amount of widgets isnt very important.
i can make 15 others for you in Hadashboard, but you probably would never use them.
i started trying out if i can make our dashboard a bit more slick looking like FHEM.
lots of things are possible, without even changing anything in HADashboard.
maybe we could look to find another grafikset that looks a little more slick.
but just some layout ideas taken from the other and done in HADashboard.
Thank you for explaining it to me.
I have just finish your guide, and everything is working. Thank you very much for your help.
I started facing a problem. Whenever i refresh the page both snapshot1_new and old files get deleted and if i check dashboard page for error i get http://192.168.0.211:3030/assets 404 (Not Found) . The camera image is not displaying also.It is working perfect in HA
Glad you got it working
Can anyone please help. I tried everything but i am not able to get the cameras working on Hadashboard. Getting error
âhttp://192.168.0.211:3030/assets Failed to load resource: the server responded with a status of 404 (Not Found)â if i inspect the page in chrome. If i change the ownership of the folder cameras to 775 both snapshot1 files get deleted ( i am just using 1 camera)
I need help with this error. Home assistant is up and running, and all gems and bundler seemed to install. What I use the dashing start command, this is the result:
bundler: failed to load command: thin (/usr/local/bin/thin)
SyntaxError: /home/pi/hadashboard/lib/ha_conf.rb:1: syntax error, unexpected tLABEL
$ha_url = http://10.0.0.8:8123
/var/lib/gems/2.1.0/gems/backports-3.6.8/lib/backports/std_lib.rb:9:in require' /var/lib/gems/2.1.0/gems/backports-3.6.8/lib/backports/std_lib.rb:9:in
require_with_backportsâ
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:171:in block in require_glob' /var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:170:in
eachâ
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:170:in require_glob' /var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:180:in
<top (required)>â
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing.rb:3:in require' /var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing.rb:3:in
<top (required)>â
config.ru:1:in require' config.ru:1:in
block in â
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/builder.rb:55:in instance_eval' /var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/builder.rb:55:in
initializeâ
config.ru:1:in new' config.ru:1:in
â
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/rack/adapter/loader.rb:33:in eval' /var/lib/gems/2.1.0/gems/thin-1.6.4/lib/rack/adapter/loader.rb:33:in
loadâ
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/controllers/controller.rb:182:in load_rackup_config' /var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/controllers/controller.rb:72:in
startâ
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/runner.rb:200:in run_command' /var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/runner.rb:156:in
run!â
/var/lib/gems/2.1.0/gems/thin-1.6.4/bin/thin:6:in <top (required)>' /usr/local/bin/thin:23:in
loadâ
/usr/local/bin/thin:23:in `<top (required)>â
And then it just goes back to terminal. Any help on this?
Thanks!
Also, merry Christmas Everyone!
Have you tried installing thin?
sudo apt-get install thin
i get htese errors and the package is installed:
Dec 25 17:58:18 raspberrypi systemd[1]: Started Push events from Home Assistant to Dashing.
Dec 25 17:58:20 raspberrypi hapush[21890]: Starting daemon: hapushTraceback (most recent call last):
Dec 25 17:58:20 raspberrypi hapush[21890]: File "/srv/hass/src/hadashboard/hapush/hapush.py", line 8, in <module>
Dec 25 17:58:20 raspberrypi hapush[21890]: from configobj import ConfigObj
Dec 25 17:58:20 raspberrypi hapush[21890]: ImportError: No module named 'configobj'
Got a new Pi for Christmas. I am planning to install the dashboard on it. Are there any issues with having the PI on a separate system from HA that I should be aware of?
Just tried this, installed fine, but same error when I do dashing start
