I saw something similar here a while ago. So inspired by that dashboard, I gave a shot for my own. Just basic picture frame fitted with Lenovo Tab 10HD running Fully Kiosk app with Motion Detection. Price for the setup was about 30 euros plus tablet.
I think it’s a good example of what the vanilla Lovelace can do. You don’t actually need external dashboard software to make this usable and pretty.
Backend is running on FreeNAS virtual server (ubuntu) on a docker container. Aqara sensors, Hue and Osram Lightify zigbee lights all over the place. Few Roomba vacuum cleaners and my car is also connected to this (BMW Connected Drive). Tado thermostat for floor heating. Added also home calendar for quick view.
I’ve done this before. Just buy a frame the right size, make sure it’s thick enough for a tablet and not just a picture, and remove the glass. Fit the tablet and mark where you need the charger, then cut a little notch for the cable. Depending on where you mount it you might be able to fold the charger back and hide it completely. Then put the back of the frame on. If there’s free space, you may need some foam or cardboard directly behind the tablet to space it out. Then hang it up! When I did it I used double sided tape on 4 corners so it wouldn’t wobble when you tap on it. The other trick is to put the charger on a smart outlet and automate it to turn on and off with the battery charge level on the tablet. This will extend the battery life and prevent the battery expanding and creating a fire hazard. It also raises your chances of being able to use the tablet for something else later if you get lucky and the battery isn’t totally shot
I had a Samsung Tab A7 on the wall, connected to the outlet, but in 1 year I had to change twice the battery. It swollened…
I was wondering how are you going with the tablet with 24/7 of service connected to the outlet.
With the last battery I created an automation to charge/discharge the tablet from 20% to 80%. But it will be too many continued cycles of charge, and I’m thinking to change to 10" touchscreen with a rpi connected.
