Our living room has no built in lights, just two lamps on end tables that plug into a wall outlet. I’m using this [heath zenith switch/outlet](Heath Zenith WC-6036-WH Wireless Command Add A Switch Lamp Set, White https://www.amazon.com/dp/B003IHUIIQ/ref=cm_sw_r_cp_apa_XTn6Bb0J3HQ1D) combo to control the lamps. This has a high WAF (Wife Approval Factor) since it operates the lamps like a normal switch, but it doesn’t integrate with HA.
Does anyone knowing of something similar that would integrate with HA but also have a wall switch (that I can just stick on the drywall) so I can retain the high WAF?
