Dear all,
I’m working on a Smart Car Charging automation to maximize the energy drawn from solar. It’s somehow similar to the EcoSmart feature offered by Wallbox, but as I am fully disconnected from the grid in Spain, I needed various tweaks including context of my Solar system, home battery SOC, and car SOC - all are integrated either through ModBus or existing HA integrations.
I’ve worked with NodeRed, and can really say HA+NodeRed is an impressive combination for more advanced workflows - I still need to work on bits and bytes but the current workflow does automate dynamically the charging based on solar and home requirements on my system.
Now on my question - I am looking for the API reference used by the Wallbox integration. Scrubbing the integration github file I could see the “Wallbox Portal Status Description” possible states, but miss most other accepted values (e.g. what does “Wallbox Portal current mode” equal to “3” mean?). Currently i’m learning by trial and error everytime I see an API error showing up in node red. (e.g. learning that trying to set charging to less than 6 amps fail - was expected to not work of course, but didn’t expect an API error - would be great to have the API reference for the overall view.
Any pointer would be appreciated. Already had a look at the files of wallbox · PyPI, but those don’t help much when it comes to API references.
Thanks in advance!
