Wallbox pulsar plus dynamic charging script that works for me
alias: auto charging regulation dynamic load
description: Tests changes in charging current based on simple logic.
  • platform: state
    entity_id:
    • sensor.ss_inverter_power
    • sensor.ss_grid_power
      condition:
  • variables:
    inverter_power: “{{ states(‘sensor.ss_inverter_power’) | int }}”
    grid_power: “{{ states(‘sensor.ss_grid_power’) | int }}”
    total_consumption: “{{ inverter_power + grid_power }}”
    max_inverter_power: 11300
    charge_current: >-
    states(‘number.wallbox_pulsarplus_sn_651522_maximum_charging_current’) |
    int }}
    charger_consumption: “{{ charge_current * 230 * 3 }}”
    actual_free_power: “{{ max_inverter_power - (total_consumption - charger_consumption) }}”
  • service: logbook.log
    name: EV Script Test
    message: >-
    Total house consumption: {{ total_consumption }} W, Available power: {{
    actual_free_power }} W
  • service: number.set_value
    entity_id: number.wallbox_pulsarplus_sn_651522_maximum_charging_current
    value: |-
    {% if actual_free_power >= 9800 %}
    13
    {% elif actual_free_power >= 8500 %}
    12
    {% elif actual_free_power >= 8200 %}
    11
    {% elif actual_free_power >= 7200 %}
    10
    {% elif actual_free_power >= 6500 %}
    9
    {% elif actual_free_power >= 5700 %}
    8
    {% elif actual_free_power >= 4940 %}
    7
    {% elif actual_free_power >= 4140 %}
    6
    {% else %}
    0
    {% endif %}
    message: >-
    Set charging current: {{
    }}A
    mode: single
i have used this script and it manages charging current based on house consumption . I have entered inverter power in script 11300w becuase sometimes it goes to 12000w so like this i am protecting inverter which supports output 13000w . Script works fine for me you can check out my video on youtube after i installed charger i have recorded how it works you need to replace ss inverter power with your sensor that measures whole house consumption or load and sensor ss grid power with sensor that measures power pulled from the grid . here is link to video https://www.youtube.com/watch?v=y9PxtfvAyVc
hello
I have a deye 12 kw and the same wallbox pulsar plus charger
I would like to have this dynamic control in home assistant but this script layout does not work for me please help
