I think I found the issue, if you never set a URL for your default-tab (first tab), it gets set to empty string, which in actuality makes your url be 0. The code uses activeTab here lovelace-wallpanel/wallpanel.js at 1cfbf705afd20c0796e9922e7892143340e3342b Ā· j-a-n/lovelace-wallpanel Ā· GitHub which is set from tab which is pulled from the URL here lovelace-wallpanel/wallpanel.js at 1cfbf705afd20c0796e9922e7892143340e3342b Ā· j-a-n/lovelace-wallpanel Ā· GitHub. So essentially, the URL sets the active tab. So enabled_on_tabs needs to match whatever your URL is, not necessarily your tab name.
Canāt get wallpanel to show my google photos. Is something wrong with my YAML?
Right now all it shows is random images from a random source and no matter what I do, I canāt get my photos to appear, even after granting access to the Google Photos API. I also canāt get wallpanel working on just one device, via browser mod, unless I enable it from the top, for some reason. Any help will be greatly appreciated.
wallpanel:
enabled: true
profiles:
device.idnumberhere:
enabled: true
hide_toolbar: true
hide_sidebar: true
fullscreen: true
image_fit: cover
display_time: 15
image_url: media-entity://camera.google_photos_album_namehere_media
@j-a-n
Thanks for an excellent addon! I started using it yesterday on my main tablet, because using Fotoo as a screensaver made the tablet refresh all my cards when switching back to Home Assistant as the foreground app. Thanks to your addon, I can now stay entirely in Home Assistant.
However, one of the nice features of Fotoo is that it can make the background ābokehā, based on the actual displayed image. I tried to replicate that effect by using the image_url_entity helper and then using that image as a background for a card also on the dashboard. However, for some reason it seems to not reflect the currently used imageā¦ and it is a bit of a hack. Please see my code below.
Do you think itād be possible for you to include the option to use the currently displayed image with a blur effect as a background? That way, vertical/portrait images will look a million times better on a horizontal display. Thank you. If you arenāt planning on including that option, can you then guide me on how to use the actual displayed image?
wallpanel:
enabled: true
hide_toolbar: false
hide_sidebar: true
fullscreen: false
idle_time: 0.1
image_url: media-source://media_source/local/nuc
image_fit: contain
image_order: random
display_time: 60
image_url_entity: input_text.image_url_entity
cards: []
style:
wallpanel-screensaver-container:
background-color: '#00000000'
- title: Wallpanel
sections:
- type: grid
cards:
- type: custom:button-card
styles:
card:
- width: 110vw
- height: 110vh
- margin: 0
- padding: 0
- position: fixed
- top: '-5vh'
- left: '-5vw'
- z-index: 1
- overflow: hidden
tap_action:
action: none
hold_action:
action: none
card_mod:
style: |
ha-card {
background-image: url('http://homeassistant:8123/local/images/googlephotos/{{ states('input_text.image_url_entity').split('/')[-1] }}');
background-color: black!important;
background-size: cover;
background-position: left;
filter: blur(50px) brightness(100%) saturate(1);
@j-a-n DāOH! Never mind ā found out I could just use the āimage_backgroundā thatās already included. Thanks again for all your work on this!
However, I have another question. How does the camera motion work? Canāt get it to work on my tablet (permissions allowed, tried both through Fully Kiosk, native HA app and Chrome. Of course I activated camera_motion_detection_enabled. How do I specify which camera it should use?
Thanks for this. Can you guide me on the creating the helper please for the query?
I have already created one for the Day and Night profiles called āinput_select.wallpanel_screensaverā
has anyone been able to arrange multiple views in a grid pattern on the screensaver?
I can arrange individual card by using wp_style but it does not seem to work for views
cards:
- type: custom:simple-clock-card
use_military: true
hide_seconds: false
bold_clock: false
wp_style:
grid-row: 1 / 1
grid-column: 2 / 2
align-self: start
this is the code i use for views that does not work:
- title: View1
wp_style:
grid-row: 1
grid-column: 1
align-self: start
First, thanks @j-a-n for the great work, and the rest of you for the lively discussion!
I stumbled across this strange behavior thatās been driving me crazy for a week now. When screensaver is based on a view, it always seems to append a Weather forecast Card at the end of the referenced view, always configured to use entity āweather.homeā and āShow current weather onlyā.
**Update: I have finally found an explanation here: š¼ļø WallPanel Addon - Wall panel mode for your Home Assistant Dashboards - #414 by jeffcrum **
In short: if there is no ācards:ā the addon automatically adds the Weather Forecast card, I guess for a demo effect. ācards:ā must be present even if screensaver is to use a view. Adding an empty ācards:ā to the config removes the demo weather card.
If the view is empty, it will only show the Weather Forecast card that is obviously not part of the dashboard yaml.
This phantom Weather Forecast card always refers to an entity āweather.homeā, which I didnāt even have among my entities, resulting in an āEntity not available āweather.homeāā error. As soon as I renamed one of my weather provider entities to āweather.homeā, the error got replaced by a functioning weather card. Which is not what I want.
If I use Cards: instead of Views: for the screensaver, the Weather card is not there and everything works fine.
This looks much like a bug to me. Several other users seem to have stumbled across this in the past, but I didnāt find an explanation or a solution yet.
Here is an example of a minimal dashboard that shows this behaviour. Note that there is no mention of āweather.homeā in it, and yet the entity is required, and if it exists, it gets shown in the screensaver (see screenshot).
wallpanel:
enabled: true
debug: false
hide_toolbar: false
hide_sidebar: true
fullscreen: true
idle_time: 5
- title: Screensaver
- theme: Backend-selected
title: Home
icon: mdi:home
layout: {}
type: sections
sections:
- type: grid
cards:
- type: heading
heading: New section
- type: masonry
title: Screensaver
sections: []
subview: false
cards:
- type: heading
icon: mdi:fridge
heading: Screen saver
heading_style: title
badges: []
@j-a-n Small feature request: would it be possible to add the idke_time as an input text helper entity (or similar) as well?
That way, you would be able to disable or change the idle time if for instance music is playing etc.
Thanks for your work on this again ā really feature rich!
Can you post an exemple with WallPanel that not showing any cards ?
Iām playing with this to see if it suits my use case. I started with the basic example. Issue I am experiencing is that once it is enabled, the sidebard disappears and I canāt find a way to get it back. I am testing this using an edge browser to start with then I intend to use it in my Android wall tablet once I am certain that I have configured things correctly.
Also the top menu bar disappears. I cannot find a way to take it back and cannot edit the dashboard.
Having an empty ācards:ā or ācards: nullā does the trick for me.
wallpanel:
enabled: true
debug: false
hide_toolbar: false
hide_sidebar: true
fullscreen: true
idle_time: 5
cards: null
You can use entities everywhere in the wallpanel config.
i.e.:
wallpanel:
idle_time: '${entity:input_text.wallpanel_idle_time}'
See the README for details.
An empty list would work also:
wallpanel:
cards: []
Hi!
First of, Wallpanel is such a nice thingy to setup and use as a tablet dashboard display, great work!
Iām struggling a bit with one thing tho, I use the coverart of a media player as the image and would like to blur it - and Iām been able to do it but it changes back and forth between the blurred and unblurred versions every 10s or something. This is part of the config I run right now:
image_url: ${entity:sensor.dashboard_samsung_screensaver_image_url}
image_fit: cover
style:
wallpanel-screensaver-image-one:
filter: 'blur(30px)'
opacity: 0.4
And the blur + opacity works for 10s, then it turns off for 10s, then it turns on again etc Any ideas of how I can get this to stick? Iāve tried with styling: wallpanel-screensaver-image-one-background
, wallpanel-screensaver-image-one-container
and wallpanel-screensaver-image-one
all with the same result.
I am using my NAS Synology to display pics for a screen saver.
2 questions here
Can I assign more than one folder to the line image_url: ?
Is there a way to create some kind of schedule and assign a dedicated folder based on a day / time or period of the year without having to make the change manually every time.
I have tried different options but nothing seems to work.
Is there a way to activate and deactivate the wallpanel mode based on a toggle (helper) linked to a button on the dashboard?
Hi is it possible to use Image entity as Background instead of camera entity?
I have troubles to Set Up immich as Background Service.
My Work around is to use a hacs Integration which will create image.immich_Xxx. this works and my Pictures are shown in Home assistant
Pictures are shown but im unable to use āimage_url: media-entity://ā function.
Edit: Also tried media-source://Image but also results in a blackscreenā¦
Maybe a dumb question but here goes. If I use Wall Panel settings for my dashboard I am using for my wall mounted tablets, do I need the app to keep the tablet from going to sleep, canāt remember the name at the moment, dang old age!!
There are two images between which the system automatically switches. Therefore you should set the same style on wallpanel-screensaver-image-two
too.
Thanks, that worked beautifully!
