Still inexperienced with Hass.io, I don’t know what is possible with EasyIoT and Hass.io.
What I want is a simple (cheap) solution to make a 1mtr 5V white led strip to dim with Hass.io.
I found this link, 28-esp8266-wifi-led-dimmer what I think could help me, but they take about EasyIoT server instead of Hass.io.
Can I use what is described on this page, or does it need adjustments to be used with Hass.io.
Looks like a lot of work. I use Magic Home LED controllers flashed with Tasmota they are RGB(W) but i’ve recently configured one just using white LED’s
Just now see that it is powered by 12v
I have a 5v 1mtr smd3528 led strip (white) I want to be able to dim and turn on/off using Hass.
I found this single color controller, but can it also be flashed by Tasmota?
Magic Home Mini Single Color WiFi LED http://tiny.cc/z0hz2y
