4nduril
November 30, 2023, 7:21pm
1
I don’t know if it is possible, so I ask here:
I have a ESP32 with 8 mosfets attached for dimming 8 LED strands. At the moment they are all set to the same level, but I would like to have some dynamic lighting.
The set level in HA should be the average light level. All individual levels should be pending around that value (maybe with different transition times). I want a setting of 70 to result in (62,58,74,77,68,65,71,85) transitioning to (73,55,59,71,79,80,63,80). Can that somehow be accomplished?
Regards,
4nduril
zoogara
(Daryl)
November 30, 2023, 10:42pm
2
Can you share your existing ESPHome code?
Of cause I can…
esphome:
friendly_name: LED-Dimmer-Treppe
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "XXX"
ota:
password: "XXX"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Led-Dimmer-Treppe"
password: "XXX"
captive_portal:
output:
- platform: ledc
pin: GPIO16
- platform: ledc
pin: GPIO17
- platform: ledc
pin: GPIO18
- platform: ledc
pin: GPIO19
- platform: ledc
pin: GPIO21
- platform: ledc
pin: GPIO22
- platform: ledc
pin: GPIO23
- platform: ledc
pin: GPIO25
type: float
write_action:
- output.set_level:
level: !lambda return state;
- output.set_level:
- output.set_level:
- output.set_level:
- output.set_level:
- output.set_level:
- output.set_level:
- output.set_level:
light:
- platform: monochromatic
output: outputsplit
