Good morning,
I have some mushroom entity cards set up for appliances in my home.
I’d like to add a runtime to the card, so in the above screenshot, I have my washer and dry in my laundry room. Each appliance has a Shelly 1 PM in the outlet, which allows me to monitor the power and know if the appliance is active or not.
I’ve set up sensors to tell me if the appliance is running or is idle.
- sensor:
- name: "Dryer"
state: >
{% if states("sensor.dryer_switch_0_power")|float == 0 %}
Off
{% elif states("sensor.dryer_switch_0_power")|float <= 2 %}
Standby
{% else %}
Drying
{% endif %}
icon: >
{% if states("sensor.dryer_switch_0_power") == "off" %}
mdi:tumble-dryer-alert
mdi:tumble-dryer-off
{% else %}
mdi:tumble-dryer
{% endif %}
- name: "Washing Machine"
state: >
{% if states("sensor.washer_switch_0_power")|float == 0 %}
Off
{% elif states("sensor.washer_switch_0_power")|float <= 2 %}
Standby
{% else %}
Washing
{% endif %}
icon: >
{% if states("sensor.washer_switch_0_power") == "off" %}
mdi:washing-machine-alert
mdi:washing-machine-off
{% else %}
mdi:washing-machine
{% endif %}
The mushroom card is based upon those sensors, and will tell me the state of those sensors.
type: horizontal-stack
cards:
- type: custom:mushroom-entity-card
entity: sensor.dryer
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
entity: sensor.washing_machine
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
What I’d like to add, is a runtime since start, and ideally for it to be next to the sensors state, with a dash in between. So, for example, I want to have a timer counting up from when the Washer changed from Standby to Washing. Eventually I may add cycles (spin, drain, etc) to the sensor, so I really just want the Standby to Washing to be the trigger, and Anything to Standby to stop the timer.
What is the best way to go about this?
