Hi guys, I am trying to get a DuckDNS + NPM setup to run on my fritzOS router but having significant trouble because I have very little idea about network administration and need some help.
What I have:
- a running duckDNS domain that I can ping and gets successfully resolved to my public IP.
- a proxy host in NPM with a subdomain on the duckdns domain that I want to route to my homeassistant that is marked active.
- an SSL certificate in NPM for the duckdns domain via Letsencrypt that is also marked active and assigned to the proxy host.
- DNS rebind exceptions in FritzOS for the duckdns domain + HA subdomain
- Port exceptions for my HA server on port 443 and port 80 as recommended by NPM doc.
- Got a second DuckDNS domain because that seems to work for some people but not for me.
- Logs of NPM, DuckDNS, MariaDB look fine.
But I always get timeouts when I try to reach the duckdns HA subdomain regardless of whether I am trying to connect internally or externally.
This is my configuration.yaml:
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
- 172.16.0.0/12
- 127.0.0.1
- 192.168.178.43
- ::1
cors_allowed_origins:
- https://google.com
- https://www.home-assistant.io
- https://cast.home-assistant.io
Where did I make an error?
