Found this https://bhyve.orbitonline.com/hosefaucet/ Wondering if i attach this to my faucet (on my pool pump), can i use this and control the water coming out of my pool? assuming the pool pump is on, there is a red nozzle to let water come out of that i use use to drain the pool
It appears you would need their B-Hive hub.
If you already have Alexa or Google Home, you could then use HA to control through one of them?
B-Hyve Smart Hose Faucet Timer with Wi-Fi Hub, im just trying to confirm it’s able to turn on/off the faucet
OK. I just found this at about the 4th posting. It looks like there may be an API ?
Just searching, opensprinkler may be an option.
is there a smart water feature that im missing?
I assumed the smart part would be in the Home Assistant configuration.
yes, but my use would be the opposite everyone else is using it for
Anyone have any luck getting this to work? I was thinking of getting the Orbit Timer and Hub.
There is a integration that is available. Have a look at GitHub - sebr/bhyve-home-assistant: Orbit BHyve custom component for Home Assistant
Once installed I can to do basic on/off for 2 taps connected to a single hub. Apart from installing I have really done nothing else in regards to automations etc…
