Hello, there are huge forest fires in Canada, and a lot of smog now, I used WAQI to automate my ventilation and filtering, but now after some updates it’s not working, and it happens at the only time of the year I really need it.
Has anyone had a similar issue, or a quick idea how to make it work again?
Thank you
2023-06-07 09:31:00.138 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform waqi is taking over 10 seconds.
2023-06-07 09:31:00.271 ERROR (MainThread) [homeassistant.components.sensor] waqi: Error on device update!
File "/usr/local/lib/python3.10/site-packages/waqiasync/__init__.py", line 47, in _get
resp = yield from self._session.get(
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 560, in _request
await resp.start(conn)
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 899, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.10/site-packages/aiohttp/streams.py", line 616, in read
await self._waiter
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 521, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 779, in async_device_update
await self.async_update()
File "/usr/src/homeassistant/homeassistant/components/waqi/sensor.py", line 186, in async_update
result = await self._client.get_station_by_number(self.uid)
File "/usr/local/lib/python3.10/site-packages/waqiasync/__init__.py", line 42, in get_station_by_number
return (yield from self._get(FEED_NUMBER_URL.format(number)))
File "/usr/local/lib/python3.10/site-packages/waqiasync/__init__.py", line 46, in _get
with async_timeout.timeout(self._timeout):
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 116, in __exit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 212, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
2023-06-07 09:31:00.354 ERROR (MainThread) [homeassistant.components.sensor] waqi: Error on device update!
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 536, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 540, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 901, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1152, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
ValueError: Sensor sensor.waqi_regina_[CITY]_canada has device class aqi, state class measurement unit None and suggested precision None thus indicating it has a numeric value; however, it has the non-numeric value: - (<class 'str'>)
Home Assistant 2023.5.4
Supervisor 2023.06.1
Operating System 10.2
Frontend 20230503.3 - latest
