I have two identical Warema awnings, and I would like to control them using this add-on in HA.
One awning gets detected and works as it should, but it doesn’t detect the second one.
They are on the same location just near each other, so RF range isn’t the problem.
My logs are
Add-on: Warema Bridge
Control your Warema WMS system
Add-on version: dev
You are running the latest version of this add-on.
System: Home Assistant OS 12.3 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2024.6.2
Home Assistant Supervisor: 2024.06.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[07:19:54] INFO: Starting the Warema bridge...
[07:19:54] INFO: Setting WMS_KEY to 4724B11B56AF0037082D583AC24C7CB4
[07:19:54] INFO: Setting WMS_PAN_ID to 09E5
[07:19:55] INFO: Setting WMS_CHANNEL to 17
[07:19:55] INFO: Setting WMS_SERIAL_PORT to /dev/ttyUSB1
[07:19:55] INFO: MQTT available, fetching server detail ...
[07:19:55] INFO: MQTT server settings not configured, attempting auto-discovery...
[07:19:56] INFO: Configuring 'mqtt://core-mosquitto:1883' mqtt server
[07:19:56] INFO: MQTT credentials not configured, attempting auto-discovery...
[07:19:57] INFO: Configuring 'addons' mqtt user
Connected to MQTT
Warema init completed
Scanning...
15 07:19:59.010 I Interval for position update: 30 seconds.
15 07:19:59.090 I /dev/ttyUSB1 Scanned device: EEBB01 Type 20 Actuator UP
15 07:19:59.121 I /dev/ttyUSB1 Scanned device: 84E001 Type 63 Web control
15 07:19:59.185 I /dev/ttyUSB1 Scanned device: EEBB01 Type 20 Actuator UP
15 07:19:59.203 I /dev/ttyUSB1 Scanned device: 84E001 Type 63 Web control
15 07:19:59.297 I /dev/ttyUSB1 Scanned device: EEBB01 Type 20 Actuator UP
15 07:19:59.382 I /dev/ttyUSB1 Scanned device: 84E001 Type 63 Web control
15 07:19:59.771 I wmsTimeout 750 scanRequest 000000 "{R04FFFFFF702009E502}".
15 07:19:59.840 I /dev/ttyUSB1 Scanned device: 84E001 Type 63 Web control
15 07:19:59.871 I /dev/ttyUSB1 Scanned device: EEBB01 Type 20 Actuator UP
15 07:19:59.946 I /dev/ttyUSB1 Scanned device: EEBB01 Type 20 Actuator UP
15 07:19:59.947 I /dev/ttyUSB1 Scanned device: 84E001 Type 63 Web control
15 07:20:00.055 I /dev/ttyUSB1 Scanned device: EEBB01 Type 20 Actuator UP
15 07:20:00.103 I /dev/ttyUSB1 Scanned device: 84E001 Type 63 Web control
15 07:20:00.534 I wmsTimeout 750 scanRequest 000000 "{R04FFFFFF702009E502}".
15 07:20:00.614 I /dev/ttyUSB1 Scanned device: EEBB01 Type 20 Actuator UP
15 07:20:00.663 I /dev/ttyUSB1 Scanned device: 84E001 Type 63 Web control
15 07:20:00.743 I /dev/ttyUSB1 Scanned device: EEBB01 Type 20 Actuator UP
15 07:20:00.758 I /dev/ttyUSB1 Scanned device: 84E001 Type 63 Web control
15 07:20:00.830 I /dev/ttyUSB1 Scanned device: EEBB01 Type 20 Actuator UP
15 07:20:00.910 I /dev/ttyUSB1 Scanned device: 84E001 Type 63 Web control
15 07:20:01.296 I wmsTimeout 750 scanRequest 000000 "{R04FFFFFF702009E502}".
Scanned devices.
Registering 113646
Adding device 113646 (type 20)
Registering 123012
Unrecognized device type: 63
[ { snr: 113646, snrHex: 'EEBB01', name: '113646' } ]
Best regards
Aaron
