Warm/White LED Controller with ESPHome?
Has anyone done a Warm/White LED String controller with ESP Home? Wondering if there is an easy way to integrate the Warm/White controllers with HA
Which controller?
Good question - it’s a P9813 module from Aliexpress Full Color Rgb Led Strip Driver Module Shield For Arduino R3
That is an rgb controller by the look of the pin labeling.
Correct - you can use two of the channels for controlling Warm & White leds. E.g. Red for Warm and Green for White. I’ve already wired the whole thing with a Raspberry pi and it works.
I was wondering if HA and ESPHome have any known methods of controlling led strings with Warm & White.
Have a look at the NeoPixelBus Light - that in conjunction with options from the base Light Component should give you some ideas.
This one definitely handles the P9813 but then it doesn’t have any built-in support for WW or RGBWW so not sure where I could convert the messages between HA and ESPHome to convert WW into RGB.
However, I noticed this component RGBWW Light — ESPHome. What kind of controller would I use? Looks like it is from D pin directly to LED.
That’s for driving individual LEDs. You have addressable LEDs - you need to drive them with a compatible component/driver.
Did you look at color_mode in the base light component?
I don’t see what leds he has in this thread.
Which I believe is a Neopixel controller.
yeah I see that upon further investigation.
Ah interesting - so the color_mode supports my lights but it sounds like it would still need a controller that supports the WW mode. Well - that seems relatively close, I’m going to see if I can fork the code base and possibly submit a patch for the P9813 module with WW support.
I am totally new to ESPHome - but I assume that magically it will relay the color_mode to home assistant and the controller will just appear as a light?
