Hey,
I have a RGBCCT Controller with ZigBee (This one: Amazon.de) It’s shown up as TS0505B.
But in the color configuration, I’m missing the Color temperature.
Anyone has an idea it’s not shown up?
Hey,
I fixed it!
Just removed the device out of home assistant and reconnected it.
Hope it helps some else too
How did you get your colour options? I just connected my TS0505B and all I’m getting is on/off. I’m using the HUSBZB-1 using ZHA if that matters.
Were you able to solve this? I have the same setup as you:
It seems to be supported by zigbee2mqtt, but I didn’t set mqtt yet, so I hope there is another solution using ZHA.
I just moved over to Z2M. I was having reliability and other issues with ZHA anyway so figured I’d solve two problems at once. I do still have devices in ZHA so it seems you can run both at the same time which is helpful if you don’t have the time to go through every device at once.
