Warmup integration works in HA but not node red
hello all,
I have the warmup (under tile heating ) custom component setup in HA, I can set the temp override of the warmup devices fine.
I have a simple call service flow for the warm up device in node red, i get confirmation message back but the actual temp is not changing on the device.
I have gone into dev tools and set the temp there which works fine
not sure what other way to try in node red- i’d greatly appreciate any advice
thank you
You’re sending the temperature as a string, you likely need to send a number. Just remove the quotes around the temperature.
mate thank you so much. that fixed it.
anyone else’s warmup integration just disappear? seems they’ve removed it
https://www.home-assistant.io/integrations/warmup
I think it’s available through HACS, not as a built in integration. GitHub - ha-warmup/warmup: Home Assistant integration for Warmup heating thermostats as a HACS integration or a custom component
thanks i re set it up but it was available. its just been removed recently :frowning:
Have you been able to make your WarmUp work with HomeAssistant? I’m having the same issue. Seems that it stopped working recently, probably due to the last update?
Yeah it was working fine. I think it’s down today tho. Need to check
mine is working fine still.
