I also bumped into error “Home Assistant CLI not starting jump into emergency console”, tried over dozen times with fe wSD cards and 4.x, 5.x and 6.x HA versions. Browsed all over the net and this forum, then finally noted some post with unclear instructions to “log in with any user info…” So I tried in CLI screen prompt after the original error message and just wrote “login” and pressed enter. It proceeded right to HA welcome prompt showing the urls like HA url http://homeassistant.local:8123
Observer, mikä lie http://homeassistant.local:4357. So I entered HA url into my browser and it took then 30+ min to do rest of installations and asked to register. So some silly stuck which you can bypass, propably with many login kind of attempts
