Hi
Trying to set up a standard dashboard for hassio using AppDeamon v4
Everything seems to work except the weather.weather widget.
I have Dark Sky set up in hassio. Can only see the following states in hassio
weather.dark_sky partlycloudy
temperature: 30.5
humidity: 71
ozone: 279.7
pressure: 1011.9
wind_bearing: 20
wind_speed: 8.58
visibility: 16.093
attribution: Powered by Dark Sky
forecast: [object Object],[object Object],...
friendly_name: Dark Skyh
Have tried multiple settings in main.dash file but seem to get this error in AppDeamon log:
2020-01-26 11:32:29.456057 INFO AppDaemon: Compiling dashboard 'main'
2020-01-26 11:32:31.261238 WARNING AppDaemon: Unable to find widget type 'persistent_notification'
2020-01-26 11:32:31.265784 WARNING AppDaemon: Traceback (most recent call last):
File "/usr/lib/python3.8/site-packages/appdaemon/dashboard.py", line 314, in _load_widget
with open(yaml_path, 'r') as yamlfd:
FileNotFoundError: [Errno 2] No such file or directory: '/usr/lib/python3.8/site-packages/appdaemon/widgets/persistent_notification.yaml'
2020-01-26 11:32:31.792245 INFO AppDaemon: function [get_dashboard] finished in 2354 ms
2020-01-26 11:32:32.110705 WARNING AppDaemon: Unknown entity: sensor.dark_sky_icon requested by None
2020-01-26 11:32:32.120347 WARNING AppDaemon: Unknown entity: sensor.dark_sky_temperature requested by None
2020-01-26 11:32:32.128895 WARNING AppDaemon: Unknown entity: sensor.dark_sky_apparent_temperature requested by None
2020-01-26 11:32:32.139583 WARNING AppDaemon: Unknown entity: sensor.dark_sky_precip requested by None
2020-01-26 11:32:32.146703 WARNING AppDaemon: Unknown entity: sensor.dark_sky_pressure requested by None
2020-01-26 11:32:32.152736 WARNING AppDaemon: Unknown entity: sensor.dark_sky_precip_intensity requested by None
2020-01-26 11:32:32.155239 WARNING AppDaemon: Unknown entity: sensor.dark_sky_precip_probability requested by None
2020-01-26 11:32:32.157638 WARNING AppDaemon: Unknown entity: sensor.dark_sky_humidity requested by None
2020-01-26 11:32:32.165010 WARNING AppDaemon: Unknown entity: sensor.dark_sky_wind_speed requested by None
2020-01-26 11:32:32.173894 WARNING AppDaemon: Unknown entity: sensor.dark_sky_wind_bearing requested by None
2020-01-26 11:32:32.180014 WARNING AppDaemon: Unknown entity: sensor.dark_sky_icon_1d requested by None
2020-01-26 11:32:32.182607 WARNING AppDaemon: Unknown entity: sensor.dark_sky_daily_low_temperature_1d requested by None
2020-01-26 11:32:32.189719 WARNING AppDaemon: Unknown entity: sensor.dark_sky_daily_high_temperature_1d requested by None
2020-01-26 11:32:32.192301 WARNING AppDaemon: Unknown entity: sensor.dark_sky_precip_probability_1d requested by None
2020-01-26 11:32:32.199452 WARNING AppDaemon: Unknown entity: sensor.dark_sky_precip_1d requested by None
Any ideas?
Thanks in advance!
