I am having a lot of trouble with my fibaro single/double switch 2, which are node 19, 23 and 25 in my log below.
They spam my z-wave network every second, and makes it slow to use.
I have tried to change parameter 50, 51, 53, 54, 55, 57, 58 og 59 to 0, and that does not help.
I have also tried to change parameter 50 & 54 t0 100, 51 & 55 to 120 and 53, 57, 58 & 59 to 32000, but neither that helps.
I don’t need to read the energy of these switches. Not having this problem with my fibaro dimmer 2.
Does anyone have any suggestion?
Firmware 3.3, all included unsecure.
These two values that spams my network. 50-1-value-65537, 50-2-value-65537.
2021-12-25 12:27:13.898 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:14.475 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:14.683 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:14.761 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:14.898 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:15.473 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:15.684 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:15.763 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:15.899 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:16.473 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:16.683 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:16.763 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:16.897 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:17.474 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:17.685 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:17.763 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:17.897 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:18.474 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:18.683 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:18.762 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:18.899 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:19.473 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:19.683 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:19.764 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:19.897 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:20.473 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:20.683 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:20.763 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:20.899 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:21.474 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:21.683 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:21.763 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:21.897 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:22.475 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:22.685 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:22.762 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:22.897 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:23.474 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:23.683 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:23.762 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:23.899 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:24.475 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:24.684 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:24.762 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:24.897 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:25.473 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:25.684 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:25.761 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:25.897 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:26.473 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:26.683 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:26.761 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:26.897 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
2021-12-25 12:27:27.475 INFO ZWAVE: Node 19: value updated: 50-1-value-65537 0.15 => 0.15
2021-12-25 12:27:27.684 INFO ZWAVE: Node 23: value updated: 50-1-value-65537 0.02 => 0.02
2021-12-25 12:27:27.763 INFO ZWAVE: Node 23: value updated: 50-2-value-65537 0 => 0
2021-12-25 12:27:27.897 INFO ZWAVE: Node 25: value updated: 50-1-value-65537 0.13 => 0.13
