WARNING Found 'YkYLh6x27qZDS3SX@ctRuvYT*TnYcjr9bK$7DEHbV*E6ekC5oovA4v@gUPWpufG' (see wifi->password) which looks like a substitution, but 'B7' was not declared
So this isn’t the exact warning as that one contains my wifi password, but I regenerated another with the same underlying parameters.
Is “substitution” related to secrets.yaml? What is B7? I’ve done some searching, but only found people talking about it, but not documentation saying what it actually is.
Would like some short explanation that will help me understand and research it further.
Thanks again!
It’s hard to say since you say you edited the error message, but my guess is that you have something that looks like “${B7}” in your password. This is the general format of a substitution request - “${” and “}” surrounding the key for the substitution, which in this example is “B7” and the error is saying that there is no defined substitution for B7.
Maybe what you have is a different format, but I’m guessing something in your password makes it looks like you are trying to substitute a value defined as “B7” but you have defined no such substitution. Looking at the link I gave, it seems like the curly braces are not used in some cases, so perhaps you just have $B7 in your password without the braces?
my wifi password is “Pas$word”. I put \ so it’s “Pas$word” and I get this error
ERROR Error while reading config: Invalid YAML syntax:
while scanning a double-quoted scalar
in "/config/esphome/configuration/secrets.yaml", line 3, column 16:
wifi_password: "Pas\$word"
found unknown escape character '$'
in "/config/esphome/configuration/secrets.yaml", line 3, column 21:
I only saw it when flashing and only the part of the password afther the $, but I haven’t updated to the latest version yet.
It is now displayed in other place?
