Warning: Lovelace is running in storage mode. Define resources via user interface
After adding a new lovelace card via HACS I get the above warning in my logs.
configuration.yaml snippet-
# Example configuration.yaml entry
media_source:
#frigate lovelace card
lovelace:
  resources:
    - url: /hacsfiles/frigate-hass-card/frigate-hass-card.js
      type: module
I followed the installation instructions here. Not sure if some further configuration is required?
I think maybe I’ve gotten this corrected. Made a small change to the lovelace entry in configuration.yaml-
lovelace:
  mode: yaml
  resources:
      type: module
The warning is gone from the logs but would really appreciate if someone would confirm that there’s nothing else needed.
Yes - without that it will ignore the file as the default is to use the UI.
Thanks. I had found an online article that outlined creating ui-lovelace.yaml and editing .storage/lovelace_resources but I was reluctant to start changing formats of hidden files.
I ran into exactly this in this thread:
My problem was basically that I had started using Home Assistant before Lovelace and the early iterations of Lovelace were configured in ui-lovelace.yaml. Deleting that file let me just use the Lovelace UI.
There is probably more to it than that- read the whole thread.
I’ve seen this error in my log a few times.
I’m new to HA and confused.
I have one HACS card installed, that is numbercard-box
I have the following (and only lovelace entry) in my configuration.yaml:
lovelace:
resources:
- url: /hacsfiles/numberbox-card/numberbox-card.js
type: module
should that be modified in some way?
