Hi.
I’m getting a LOT of this error:
WARNING (MainThread) [asyncio] socket.send() raised exception
i’m don’t know where to start…
Hi.
Same here! Any ideas? Thanks
Same here…
me too and its messing with my automations
2017-12-21 08:04:18 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=26 from 2017-12-21 07:45:33.874641)
2017-12-21 08:04:48 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2017-12-21 08:04:48 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2017-12-21 08:04:48 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2017-12-21 08:04:48 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-12-21 08:04:58 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
2017-12-21 08:05:00 WARNING (MainThread) [homeassistant.setup] Setup of remote is taking over 10 seconds.
2017-12-21 08:05:01 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2017-12-21 08:05:18 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-12-21 08:53:31 WARNING (MainThread) [asyncio] socket.send() raised exception.
2017-12-21 08:53:34 WARNING (MainThread) [asyncio] socket.send() raised exception.
2017-12-21 08:53:34 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
Same thing:
2019-06-17 16:16:59 WARNING (MainThread) [asyncio] socket.send() raised exception.
Same thing.
same thing here. did you managed to sort it out ?
seeing same thing today, where is it coming from ?
Same! Any solution?
