After upgrading to 2023.1.6, my Slimme Meter integration is broken from time to time, every few minutes or so. Anyone has workaround? This never happened on previous versions.
Logs showed these:
It’s P1 ethernet mini from Marcel Zuidwijk
2023-01-21 23:23:36.736 WARNING (MainThread) [dsmr_parser.clients.protocol] keep-alive check failed
2023-01-21 23:23:36.737 INFO (MainThread) [dsmr_parser.clients.protocol] disconnected because of close/abort.
2023-01-21 23:26:06.745 WARNING (MainThread) [dsmr_parser.clients.protocol] keep-alive check failed
2023-01-21 23:26:06.746 INFO (MainThread) [dsmr_parser.clients.protocol] disconnected because of close/abort.
2023-01-21 23:28:36.752 WARNING (MainThread) [dsmr_parser.clients.protocol] keep-alive check failed
2023-01-21 23:28:36.752 INFO (MainThread) [dsmr_parser.clients.protocol] disconnected because of close/abort.
