WARNING [supervisor.auth] the user ‘myId’ is not registered"
I can’t login to my HA even I got proper login and password. When I do on my HAOS CLI: tried on my ha cli: au reset --username "marcin" --password "newpassword"
and get Error: unkown error, see supervisor
EDIT: on supervisor logs got info that: " WARNING [supervisor.auth] the user ‘marcin’ is not registered"
Same problem here. This is really bad. Will be very unhappy if I have to nuke my whole install because of this.
having the same issue. Used “grep username .storage/auth”
and it returned my username.
Once I tried to change using “auth reset” I get the same “Unknown error see supervisor”. The log then says my username is not registered.
I have the same issue. I can’t delete the user to recreate it either.
ok, so I looked at my root/config/.storage/auth file upon looking at that, I found that the username displayed in home assistant is NOT the same username I log in with. The username I log in with is in that file, and once I found that, I was able to log in.
the same issue here, but the user name is totally the same as in config/.storage/auth…
UPD: the answer is Display name is not the same as User name… all needed in “credentials” section:
    "credentials": [
        "data": {
          "username": "admin"
Anyone ever figured out how to solve this? I am observing the very same behaviour but different than in @deniselenok’s case i am using the right username.
Nope - this happened to me since updating to 2025.2
No way to log in with correct U/N & P/W
Last time it did this I had to use an old backup and work up through all the partials, but this time it keeps happening on the auto backup from yesterday morning.
If I try to login on a browser, I get an Onboarding error.
There’s nothing of any use in the supervisor log
