I’ll update the title when it’s working but for now, it you rely on USB devices… zwave, zigbee dongles, etc… hold off on upgrading
Has anyone upgraded their Synology to 7.2 and have their USB working?
My USB stopped working after the upgrade and I can’t find the correct cp210x.ko
I have the DS918+ which uses Apollolake and downloaded the file from
no, but the beauty of Zigbee2MQTT and Zwave JS UI is that since it sends to MQTT, i simply installed them on another machine I had which is running Fridate. When I was first testing them in order to move from SmartThings, I had them on a rpi2.
There was a time my SONOFF dongle recognised in different name under ttyACM0 and I could use it to modify Z2M config. All worked for about 30 min and USB disappeared again.
Unfortunately I can’t confirm it’s working on my DS420+ with the SONOFF dongle after having updated to DSM 7.2
All 7.2 drivers for geminilake will fail with “Invalid module format” after “trying to insmod”.
Did the upgrade yesterday and ran also into this problem, my Arduino RFlink came back fine but my ZigBee II usb stick did not connect to DECONZ.
I can confirm I have it all working now on my Synology DS1019+ where I have HA running on a virtual machine. The VM did see both USB devices but DECONZ did see the stick disconnected.
I mainly used the link @haproby posted, thanks! this needed a few tweaks so for the not so techn ical users like me, this is what worked for me, off course all credits to the original poster Scrapix!
You need to have SynoCommunity installed in the package center on your
SynoCommunity https://synocommunity.com/
Then install the Git package.
connect with a terminal to the Synology and do next command one by one
Hi @modderhut, many many thanks for your message. After my synology update earlier today my Conbee 2 stick did not work anymore.
After following your instruction, all was OK again. Thanks for taking the time to write such a clear and concise instruction. You saved me a lot of hours of troubleshooting.
Dear all, I have read all the post carefully but still can’t solve my issue.
I can’t maintain my mqtt2zigbee installation up. I always get same error:
Let me tell you that I’m running mosquito-mqtt docker with no issues under Synology NAS and that issue is after installing docker of zigbee2mqtt and try to start up the docker service.
I get this error even after following the steps on this feed and can see properly the ttyUSB0 device when listing under dev$ directory.
Zigbee2MQTT:error 2023-08-19 20:41:52: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-08-19 20:41:52: Failed to start zigbee
Zigbee2MQTT:error 2023-08-19 20:41:52: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-08-19 20:41:52: Exiting...
Zigbee2MQTT:error 2023-08-19 20:41:52: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyUSB0'
at SerialPort.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:200:28)
at SerialPort._error (/app/node_modules/@serialport/stream/dist/index.js:75:22)
at /app/node_modules/@serialport/stream/dist/index.js:111:18
I think the origin of the error could be here:
Can someone help me to find the solution to my issue?
Edit: found the culprit! It took me several hours to figure it out. The VM for some reason lost connection with the dongle. It got dismounted. All I had to do is to mount it again from DSM control panel!
I followed the above steps and I believe that I’m on the right track, however Home Assistant is failing to see the SONOFF stick form Settings>Hardware>All Hardware.
Home Assistant is running in a Virtual Machine.
I can see ttyAMC1 in Synology SSH when I type lsusb
or when I’m in the dev directory.
But for some reason it disappeared from Home Assistant, and zigbee2mqtt is failing to connect.
Zigbee2MQTT:error 2023-08-27 00:13:57: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-08-27 00:13:57: Failed to start zigbee
Zigbee2MQTT:error 2023-08-27 00:13:57: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-08-27 00:13:57: Exiting...
Zigbee2MQTT:error 2023-08-27 00:13:58: Error: Connection not initialized
This all happened out of the blue. Didn’t update HA, nor did I change anything in Synology. It just suddenly disappeared and all the zigbee devices are stranded in the middle of the desert…
