Washer Machine Notification
Hi:
I added the washing machine to my HA and I need help with the notifications part. I’m still in the stage of learning Yaml. I am trying to send 3 notifications in 15min intervals to alexa or until the door changes to open state. I really can’t figure out how to do it. With the code I have, it continues to send notifications even when the door is already open. If someone can help me I will be grateful.
JR
    # iOS Devices
    - service: notify.all_devices
        message: "The Washer Machine has finished and is ready to be emptied!"
        title: "Washing Machine"
    # Echos Devices
    - repeat:
        until:
          - condition: state #Verificar en prueba si es necesario esta instruccion
            entity_id: input_select.washing_machine_status
            state: "Clean"
        sequence:
          - service: notify.alexa_media
              message: "{{ [
                'La lavadora terminó el ciclo y esta lista para que saques la ropa',
                'No pretendo interrumpir, pero, no olvides pasar la ropa a la secadora.',
                'Aqui estoy para recordarles que la lavadora terminó, please saquen la ropa.',
                '¿Te gusta que tu ropa huela apestosa? Porque eso es lo que esta sucediendo ahora mismo si no la sacas de la lavadora.',
                'Espero no molestar, pero si dejas la ropa en la lavadora vas a terminar lavándola de nuevo'
                ] | random
                - media_player.jesmar_kitchen
                - media_player.family_room
                type: tts
          - wait_for_trigger:
              - platform: state
                entity_id: binary_sensor.washer_door
                to: 'on'
            timeout: "00:15:00"
I’m not sure what the input_select condition is for in the repeat util section so I’ve removed it so if you really need it you can put it back in.
but I think you can do this:
    # iOS Devices
    # Echos Devices
    - repeat:
        until:
          - condition: or
            conditions:
              - condition: state
                state: 'on'
              - condition: template
                value_template: "{{ repeat.index == 3 }}"
        sequence:
              message: "{{ [
                ] | random
                type: tts
            delay: "00:15:00"
Thank for your help finity!!!
The input_select is used so that the notification is only sent when the washing machine is already in the clean state and not in running or idle. I will try the code :slight_smile:
JR
When I add the code it is giving me this error.
Invalid config for [automation]: [service] is an invalid option for [automation]. Check: automation->action->1->repeat->sequence->0->service. (See ?, line ?).
# Washer Machine Notifications when is finished
- alias: Send alert when Washer Machine is finished
    - platform: state
      entity_id: sensor.washing_machine_status
      to: Clean
  condition:
    condition: and
    conditions:
      - condition: state
        state: Clean
      - condition: time
        before: "23:30:00"
        after: "08:30:00"
    # iOS Devices
    # Echos Devices
    - repeat:
        until:
          - condition: or
            conditions:
              - condition: state
                state: 'on'
        sequence:
              message: "{{ [
                ] | random
                type: tts
            delay: "00:15:00"
Change this:
            delay: "00:15:00"
to this:
          - delay: "00:15:00"
Thank 123 Taras for your help.
I did the test and it continues to send notifications after the door is opened. Any advice?
Thank!
Use repeat - while with a slightly different condition.
    - repeat:
        while: "{{ is_state('binary_sensor.washer_door', 'off') and repeat.index <= 3 }}"
        sequence:
          ... etc ...
It still continues to send the notification after opening the door. When the status of “input_select.washing_machine_status” changes to Idle it is not supposed to send the notification but even in idle it continues to send it. Is it possible to put this condition in tthe repeat -while loop?
Thank you for taking the time to help me.
    - platform: state
      entity_id: switch.tasmota
      to: 'on'
  condition:
    condition: and
    conditions:
      - condition: time
        before: "23:30:00"
        after: "08:30:00"
      - condition: state
        state: Clean
    # Echos Devices
    - repeat:
        sequence:
              message: "{{ [
                ] | random
                type: tts
          - delay: "00:15:00"
Yes. Simply add it to while’s condition.
    - platform: state
      to: 'on'
  condition:
    condition: and
    conditions:
      - condition: time
        before: "23:30:00"
        after: "08:30:00"
      - condition: state
        state: 'Clean'
    # Echos Devices
    - repeat:
        while: "{{ is_state('binary_sensor.washer_door', 'off') and repeat.index <= 3 and not is_state('input_select.washing_machine_status', 'Idle') }}"
        sequence:
              message: "{{ [
                ] | random
                type: tts
          - delay: "00:15:00"
Thank!!! Worked perfectly. :smiley:
