This is my flow, hope is copy well, and sorry for the spanish but is my main language and a need some quotes to remember, what im trying to achieve is a simple flow to get a notification when the laundry or dryer is done.
I used a few examples from the forum, but honestly many of them trigger even when im not using the washing machine.
[{"id":"7a34c540.8f84c4","type":"tab","label":"Lavanderia","disabled":false,"info":"","env":[]},{"id":"460265d7ba75fba3","type":"group","z":"7a34c540.8f84c4","name":"Lavadora Power check","style":{"label":true},"nodes":["b1547d02.33153","80540aed.a59958","9cb145cdbee03a9c","c2049748089b29f5","31c4befbd89ee158","8078f42256b41c85"],"x":14,"y":79,"w":812,"h":122},{"id":"427dd904b467cd54","type":"group","z":"7a34c540.8f84c4","name":"MQTT ","style":{"label":true},"nodes":["b6a9df0c6027cb02","64e8f5cb7fdf1cc3","2417f1dbf67cc025","f2b62b48ed17faef"],"x":914,"y":79,"w":312,"h":142},{"id":"c9fc0aef5b95cadf","type":"group","z":"7a34c540.8f84c4","name":"Secadora Power check","style":{"label":true},"nodes":["8a19c92d3935a570","eb0453f5904780d1","32f43eaf91ed64b7","c2b90b7429a0d609","1804953737e0dec6","50ed25291446bf35","dfdd86690b7a8e0f"],"x":14,"y":499,"w":852,"h":182},{"id":"018640f73fed4ce9","type":"group","z":"7a34c540.8f84c4","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["2c58824dcca1c676","83b81f3404c3fa44","7f5e14273692a01d","7d9c5b204ccc517e","4dd92ba684b40c1e","6f098ccdb15054e1","8f6b9ccd4d9b6188","69a785f925d12248"],"x":14,"y":239,"w":1012,"h":162},{"id":"72678095323e27f1","type":"group","z":"7a34c540.8f84c4","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["2f1188216004fa0a","13a0382b2adcf375","76ca4dbdb5aea3c2","ef79e8fd8a6ef307","63868916b5953faf","a211e142b336bbb6","1853316e92580ff5","67e4c8e9138d531d","725d42bab63436dc","c14a78c786ed01ce","890b3ced20c7d9fa","793119d51cdbbd8b","c00759b40530cc9a"],"x":14,"y":699,"w":1012,"h":222},{"id":"b1547d02.33153","type":"switch","z":"7a34c540.8f84c4","g":"460265d7ba75fba3","name":"Check power","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"gt","v":"10","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":270,"y":160,"wires":[["c2049748089b29f5"],["9cb145cdbee03a9c"]]},{"id":"80540aed.a59958","type":"server-state-changed","z":"7a34c540.8f84c4","g":"460265d7ba75fba3","name":"Lavadora Power","server":"063846561e68d38f","version":6,"outputs":1,"exposeAsEntityConfig":"","entities":{"entity":["sensor.lavadora_energy_power"],"substring":[],"regex":[]},"outputInitially":true,"stateType":"num","ifState":"","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":120,"wires":[["b1547d02.33153"]]},{"id":"b6a9df0c6027cb02","type":"mqtt out","z":"7a34c540.8f84c4","g":"427dd904b467cd54","name":"mqtt washer state","topic":"house/washer/status","qos":"2","retain":"true","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"15faf22da4efca08","x":1110,"y":120,"wires":[]},{"id":"9cb145cdbee03a9c","type":"change","z":"7a34c540.8f84c4","g":"460265d7ba75fba3","name":"lavadora lavando","rules":[{"t":"set","p":"payload","pt":"msg","to":"Lavando","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":160,"wires":[["31c4befbd89ee158","8078f42256b41c85"]]},{"id":"c2049748089b29f5","type":"change","z":"7a34c540.8f84c4","g":"460265d7ba75fba3","name":"lavadora apagada","rules":[{"t":"set","p":"payload","pt":"msg","to":"Apagada","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":120,"wires":[["31c4befbd89ee158"]]},{"id":"31c4befbd89ee158","type":"link out","z":"7a34c540.8f84c4","g":"460265d7ba75fba3","name":"mqtt lavadora out","mode":"link","links":["64e8f5cb7fdf1cc3"],"x":635,"y":120,"wires":[]},{"id":"64e8f5cb7fdf1cc3","type":"link in","z":"7a34c540.8f84c4","g":"427dd904b467cd54","name":"mqtt lavadora in","links":["31c4befbd89ee158"],"x":955,"y":120,"wires":[["b6a9df0c6027cb02"]]},{"id":"8a19c92d3935a570","type":"server-state-changed","z":"7a34c540.8f84c4","g":"c9fc0aef5b95cadf","name":"Secadora Power","server":"063846561e68d38f","version":6,"outputs":1,"exposeAsEntityConfig":"","entities":{"entity":["sensor.secadora_energy_power"],"substring":[],"regex":[]},"outputInitially":true,"stateType":"num","ifState":"","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":560,"wires":[["1804953737e0dec6"]]},{"id":"eb0453f5904780d1","type":"change","z":"7a34c540.8f84c4","g":"c9fc0aef5b95cadf","name":"secadora secando","rules":[{"t":"set","p":"payload","pt":"msg","to":"Secando","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":640,"wires":[["c2b90b7429a0d609"]]},{"id":"32f43eaf91ed64b7","type":"change","z":"7a34c540.8f84c4","g":"c9fc0aef5b95cadf","name":"secadora apagada","rules":[{"t":"set","p":"payload","pt":"msg","to":"Apagada","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":540,"wires":[["c2b90b7429a0d609"]]},{"id":"c2b90b7429a0d609","type":"link out","z":"7a34c540.8f84c4","g":"c9fc0aef5b95cadf","name":"mqtt secadora out","mode":"link","links":["f2b62b48ed17faef"],"x":825,"y":640,"wires":[]},{"id":"1804953737e0dec6","type":"switch","z":"7a34c540.8f84c4","g":"c9fc0aef5b95cadf","name":"power check","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"lte","v":"11","vt":"num"},{"t":"gt","v":"15","vt":"num"}],"checkall":"true","repair":false,"outputs":3,"x":290,"y":560,"wires":[["dfdd86690b7a8e0f"],["50ed25291446bf35"],["eb0453f5904780d1"]]},{"id":"2417f1dbf67cc025","type":"mqtt out","z":"7a34c540.8f84c4","g":"427dd904b467cd54","name":"mqtt dryer state","topic":"house/dryer/status","qos":"2","retain":"true","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"15faf22da4efca08","x":1100,"y":180,"wires":[]},{"id":"f2b62b48ed17faef","type":"link in","z":"7a34c540.8f84c4","g":"427dd904b467cd54","name":"mqtt secadora in","links":["c2b90b7429a0d609","793119d51cdbbd8b"],"x":955,"y":180,"wires":[["2417f1dbf67cc025"]]},{"id":"66cfc37c739390c1","type":"comment","z":"7a34c540.8f84c4","name":"Secadora","info":"","x":80,"y":460,"wires":[]},{"id":"7062cb34744548cc","type":"comment","z":"7a34c540.8f84c4","name":"Lavadora","info":"","x":80,"y":40,"wires":[]},{"id":"8078f42256b41c85","type":"api-call-service","z":"7a34c540.8f84c4","g":"460265d7ba75fba3","name":"prender secadora","server":"063846561e68d38f","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.secadora"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":710,"y":160,"wires":[[]]},{"id":"50ed25291446bf35","type":"change","z":"7a34c540.8f84c4","g":"c9fc0aef5b95cadf","name":"secadora inactiva","rules":[{"t":"set","p":"payload","pt":"msg","to":"Inactiva","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":600,"wires":[["c2b90b7429a0d609"]]},{"id":"dfdd86690b7a8e0f","type":"api-current-state","z":"7a34c540.8f84c4","g":"c9fc0aef5b95cadf","name":"Secadora plug is off?","server":"063846561e68d38f","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.secadora","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":540,"wires":[["32f43eaf91ed64b7"],[]]},{"id":"2c58824dcca1c676","type":"trigger-state","z":"7a34c540.8f84c4","g":"018640f73fed4ce9","name":"Lavadora change to Apagada","server":"063846561e68d38f","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.estado_lavadora"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"previous_state","propertyValue":"old_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"Lavando"},{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"Apagada"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":160,"y":280,"wires":[["83b81f3404c3fa44"],[]]},{"id":"83b81f3404c3fa44","type":"delay","z":"7a34c540.8f84c4","g":"018640f73fed4ce9","name":"Wait a minute","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":400,"y":360,"wires":[["7f5e14273692a01d"]]},{"id":"7f5e14273692a01d","type":"api-current-state","z":"7a34c540.8f84c4","g":"018640f73fed4ce9","name":"check lavadora state","server":"063846561e68d38f","version":3,"outputs":2,"halt_if":"Apagada","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.estado_lavadora","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":280,"wires":[["7d9c5b204ccc517e"],["83b81f3404c3fa44"]]},{"id":"7d9c5b204ccc517e","type":"chronos-switch","z":"7a34c540.8f84c4","g":"018640f73fed4ce9","name":"between 9-21","config":"4a814fd34380283b","baseTime":"","baseTimeType":"msgIngress","conditions":[{"operator":"between","label":"between 9:00 and 21:00","operands":[{"type":"time","value":"9:00","offset":0,"random":false,"precision":"millisecond"},{"type":"time","value":"21:00","offset":0,"random":false,"precision":"millisecond"}]},{"operator":"otherwise","label":"otherwise"}],"stopOnFirstMatch":false,"outputs":2,"x":680,"y":280,"wires":[["8f6b9ccd4d9b6188"],["69a785f925d12248"]]},{"id":"4dd92ba684b40c1e","type":"link out","z":"7a34c540.8f84c4","g":"018640f73fed4ce9","name":"to all phones","mode":"link","links":["27260df67cc918b8"],"x":945,"y":340,"wires":[]},{"id":"6f098ccdb15054e1","type":"link out","z":"7a34c540.8f84c4","g":"018640f73fed4ce9","name":"laundry msg","mode":"link","links":["1321cc54f1659499"],"x":985,"y":280,"wires":[]},{"id":"2f1188216004fa0a","type":"trigger-state","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"Secadora change to Inactiva","server":"063846561e68d38f","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.estado_secadora"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"previous_state","propertyValue":"old_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"Secando"},{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"Inactiva"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":160,"y":740,"wires":[["13a0382b2adcf375"],[]]},{"id":"13a0382b2adcf375","type":"delay","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"Wait a minute","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":400,"y":820,"wires":[["76ca4dbdb5aea3c2"]]},{"id":"76ca4dbdb5aea3c2","type":"api-current-state","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"check secadora state","server":"063846561e68d38f","version":3,"outputs":2,"halt_if":"Inactiva","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.estado_secadora","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":740,"wires":[["ef79e8fd8a6ef307"],["13a0382b2adcf375"]]},{"id":"ef79e8fd8a6ef307","type":"chronos-switch","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"between 9-21","config":"4a814fd34380283b","baseTime":"","baseTimeType":"msgIngress","conditions":[{"operator":"between","label":"between 9:00 and 21:00","operands":[{"type":"time","value":"9:00","offset":0,"random":false,"precision":"millisecond"},{"type":"time","value":"21:00","offset":0,"random":false,"precision":"millisecond"}]},{"operator":"otherwise","label":"otherwise"}],"stopOnFirstMatch":false,"outputs":2,"x":680,"y":740,"wires":[["1853316e92580ff5"],["67e4c8e9138d531d"]]},{"id":"63868916b5953faf","type":"link out","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"to all phones","mode":"link","links":["27260df67cc918b8"],"x":945,"y":800,"wires":[]},{"id":"a211e142b336bbb6","type":"link out","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"laundry msg","mode":"link","links":["1321cc54f1659499"],"x":985,"y":740,"wires":[]},{"id":"1853316e92580ff5","type":"api-render-template","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"random msg","server":"063846561e68d38f","version":0,"template":"{{ [\n \"Perdón, pero la secadora terminó su ciclo, no olviden darle las gracias.\", \"Discúlpenme, pero, la secadora ya se detuvo.\", \n \"La secadora ha terminado, es hora de ponerse a dieta, porque de seguro la ropa se encogió.\", \n \"Se que estan ocupados, pero, la secadora terminó, hora de doblar la ropa.\", \n \"Atención, la secadora termino, aplausos.\", \n \"No quiero entrometerme, pero, ya que la secadora termino, doble y guarde la ropa.\",\n \"El ser humano ha llegado a la luna, pero aun no inventa una secadora que tambien doble la ropa, asi que le toca a usted ese trabajo, la secadora terminó.\", \n \"Solo un aviso rápido, la secadora terminó, pase a doblar y guardar la ropa.\"\n] | random }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":870,"y":740,"wires":[["a211e142b336bbb6"]]},{"id":"67e4c8e9138d531d","type":"change","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"msg secadora termino","rules":[{"t":"set","p":"payload","pt":"msg","to":"La Secadora ya termino","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":800,"wires":[["63868916b5953faf"]]},{"id":"8f6b9ccd4d9b6188","type":"api-render-template","z":"7a34c540.8f84c4","g":"018640f73fed4ce9","name":"random msg","server":"063846561e68d38f","version":0,"template":"{{ [\n \"Perdón, pero la lavadora terminó su ciclo de lavado, no olvide mover la ropa a la secadora.\", \n \"Discúlpenme, pero, la lavadora dejo de lavar, recuerde mover la ropa a la secadora.\",\n \"No deseo interrumpir, pero, la lavadora ya terminó, no olvide ponerla en la secadora.\",\n \"Odio interrumpir así, pero, la lavadora terminó, no olvide mover la ropa a la secadora.\",\n \"Le ruego me disculpe, pero, le informo que la lavadora terminó, no olvide mover la ropa a la secadora.\",\n \"No quiero entrometerme, pero, comentarle que la lavadora terminó, recuerde ponerla en la secadora.\",\n \"Siento interrumpir, pero, terminó el lavado, pase la ropa a la secadora.\",\n \"Solo un aviso rápido, la lavadora terminó, pase la ropa a la secadora.\"\n] | random }}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":870,"y":280,"wires":[["6f098ccdb15054e1"]]},{"id":"69a785f925d12248","type":"change","z":"7a34c540.8f84c4","g":"018640f73fed4ce9","name":"msg lavadora termino","rules":[{"t":"set","p":"payload","pt":"msg","to":"La Lavadora ya termino","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":340,"wires":[["4dd92ba684b40c1e"]]},{"id":"725d42bab63436dc","type":"trigger-state","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"Secadora Power <12","server":"063846561e68d38f","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.secadora_energy_power"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"previous_state","propertyValue":"old_state.state","comparatorType":">","comparatorValueDatatype":"num","comparatorValue":"12"},{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"<=","comparatorValueDatatype":"num","comparatorValue":"11"}],"customOutputs":[],"outputInitially":false,"stateType":"num","enableInput":false,"x":140,"y":880,"wires":[["c00759b40530cc9a"],[]]},{"id":"c14a78c786ed01ce","type":"api-call-service","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"apagar secadora","server":"063846561e68d38f","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.secadora"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":630,"y":880,"wires":[["890b3ced20c7d9fa"]]},{"id":"890b3ced20c7d9fa","type":"change","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"secadora apagada","rules":[{"t":"set","p":"payload","pt":"msg","to":"Apagada","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":880,"wires":[["793119d51cdbbd8b"]]},{"id":"793119d51cdbbd8b","type":"link out","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"mqtt secadora out","mode":"link","links":["f2b62b48ed17faef"],"x":985,"y":880,"wires":[]},{"id":"c00759b40530cc9a","type":"api-current-state","z":"7a34c540.8f84c4","g":"72678095323e27f1","name":"check secadora state","server":"063846561e68d38f","version":3,"outputs":2,"halt_if":"Inactiva","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.estado_secadora","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"30","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":400,"y":880,"wires":[["c14a78c786ed01ce"],[]]},{"id":"063846561e68d38f","type":"server","name":"Home Assistant","version":5,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":": ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"default","statusTimeFormat":"h:m","enableGlobalContextStore":false},{"id":"15faf22da4efca08","type":"mqtt-broker","name":"","broker":"192.168.0.198","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"3","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"4a814fd34380283b","type":"chronos-config","name":"casa chronos","latitudeType":"num","longitudeType":"num","timezone":"America/Lima","sunPositions":[]}]
