I’m looking for a away to get a notification when my dumb (not smart) washing machine is finished.
I already have serveral sonoffs in my house. I’m thinking about using a pow r2 to do this.
So my idea is to track the power consumption. The trigger would be a falling power value under a certain threshold.
Is someone else here using a sonoff pow to do this? If yes could you post an example of your config?
I have heard of those catching on fire when connected to dryers/washers. I would use a smart plug to do this. I do exactly what you are trying to do with this package.
Sorry this was spose to be a direct link to the appliance package anyway its in there.
Ive done it with a HS110 as well. Ended up having an input_select which contain states like idle/rinse/wash/spin and then using automations to allow the cycle to progress in that order (only in that order). Then notify me only when it gets back to idle from spin.
One or one hundred would you risk it over saving $15-20 for a device that doesn’t have any c tick approvals so wouldn’t be covered by insurance let alone what else could happen.
## Washing Machine Alerts
- alias: Send alert when washing machine is finished
- platform: state
entity_id: sensor.washing_machine_status
to: Clean
for:
minutes: 1
- platform: state
entity_id: device_tracker.admin_samsung
to: 'home'
for:
minutes: 2
- platform: state
entity_id: device_tracker.admin_iphone
to: 'home'
for:
minutes: 2
- platform: time
at: '20:45:00'
condition:
condition: and
conditions:
- condition: time
before: '21:00:00'
after: '08:30:00'
- condition: state
entity_id: group.family
state: 'home'
- condition: state
entity_id: input_select.washing_machine_status
state: Clean
- condition: state
entity_id: input_boolean.disable_washing_machine_notification
state: 'off'
- condition: template
value_template: >
{% if states.automation.send_alert_when_washing_machine_is_finished.last_triggered is not none %}
{% if as_timestamp(now()) | int - as_timestamp(states.automation.send_alert_when_washing_machine_is_finished.attributes.last_triggered) | int > 1800 %} true {% else %} false
{% endif %}
{% else %}
false
{% endif %}
- service: tts.google_say
entity_id: media_player.tts_kodi
message: 'The washing machine has finished and is ready to be emptied'
- service: notify.pushbullet
I trigger an input_boolean, which then is triggered once when set, then every thirty minutes (if I’m home); it notifies me by TTS on my Google Home and via Hangouts. I then turn off this input_boolean through Google Assistant once I empty the appliance. If I’m not home, the input_boolean stores the state till I do get home and it then tells me as part of my arrive home TTS sequence.
- id: appliances_wash_to_idle
alias: 'Appliances - Toggle Notifications'
- platform: state
entity_id: input_select.state_dishwasher
to: 'Powered Down'
- platform: state
entity_id: input_select.state_washingmachine
to: 'Idle'
- platform: state
entity_id: input_select.state_dryer
to: 'Idle'
data_template:
entity_id: >-
{%- if (trigger.entity_id == "input_select.state_dishwasher") %}
input_boolean.empty_dishwasher
{%- elif (trigger.entity_id == "input_select.state_washingmachine") %}
input_boolean.empty_washingmachine
{%- elif (trigger.entity_id == "input_select.state_dryer") %}
input_boolean.empty_dryer
{% else %}
{%- endif %}
- id: empty_appliances_notification
alias: 'Notification - Empty Washer/Dryer/Dishwasher'
- platform: time
minutes: '/30'
seconds: 00
- platform: state
entity_id: input_boolean.empty_dishwasher, input_boolean.empty_washingmachine, input_boolean.empty_dryer
to: 'on'
condition:
- condition: state
entity_id: group.people_status
state: 'home'
- condition: or
conditions:
- condition: state
state: 'on'
- condition: state
entity_id: input_boolean.empty_washingmachine
state: 'on'
- condition: state
entity_id: input_boolean.empty_dryer
state: 'on'
- service: script.send_dishwasher_alert
- delay: '00:00:06'
- service: script.send_washingmachine_alert
- delay: '00:00:06'
- service: script.send_dryer_alert
send_washingmachine_alert:
sequence:
- condition: state
state: 'on'
entity_id: group.google_home_speakers
message: "The washing machine's cleaning cycle has finished and it needs to be emptied."
- service: script.send_hangouts_message
data_template:
welcome_home_sequence:
sequence:
data_template:
entity_id: >
{% if source is defined %}
{{ source }}
{% else %}
{% endif %}
message: >
{{ ["Welcome home","Welcome back","Greetings"] | random }}. {%- if (states.input_boolean.empty_dishwasher.state == 'on') and (states.input_boolean.empty_dryer.state == 'on') and (states.input_boolean.empty_washingmachine.state == 'on') %} The dishwasher, dryer and washing machine completed while you were out and requires to be emptied.
{%- elif (states.input_boolean.empty_dishwasher.state == 'on') and (states.input_boolean.empty_dryer.state == 'on') %} The dishwasher and dryer completed while you were out and requires to be emptied.
{%- elif (states.input_boolean.empty_dishwasher.state == 'on') and (states.input_boolean.empty_washingmachine.state == 'on') %} The dishwasher and washing machine completed while you were out and requires to be emptied.
{%- elif (states.input_boolean.empty_dryer.state == 'on') and (states.input_boolean.empty_washingmachine.state == 'on') %} The dryer and washing machine completed while you were out and requires to be emptied.
{%- elif (states.input_boolean.empty_dryer.state == 'on') %} The dryer completed while you were out and requires to be emptied.
{%- elif (states.input_boolean.empty_washingmachine.state == 'on') %} The washing machine completed while you were out and requires to be emptied.
{%- elif (states.input_boolean.empty_dishwasher.state == 'on') %} The dishwasher completed while you were out and requires to be emptied.
{%- endif %}
Code is a little bit messy and could be cleaned up but has been about 99% reliable. My dishwasher seems to mix it up sometimes with its power draw so this one is the 1% unreliable
This should be fairly simple. As trigger you take the power consumption and if it goes to below, say, 2 then you trigger a notification. I do this with my washing machine and dryer and they trigger a notification via simplepush and a TTS message to my Google Home.
Is there a way to do these TTS messages with Alexa or Siri (on Homepod)? I don’t have a Google Home, but I’d love to have those voice notifications too.
Is there a way to hold that tts messages until a motion sensor near alexa is fired?
I think I would use a input boolean which is set to on when the washing machine is finished.
In another automation I‘ll use the motion sensor as a trigger and the Input boolean as condition.
In „action“ I would reset the Input boolean and send the tts message.
Thats the way I’ve done it. I use it to trigger a home TTS message, and a static wait time meant most times I’d miss it. The input-boolean stores the trigger, and then switches off after the script runs.
you can use wait_template: in the action of the automation with the motion sensor being the thing that the automation waits for. very easy. check the docs for wait_template:
My issue is that in certain washingprograms the energyvalue goes under 3 watts while washing for serval minutes. This triggers my notification, because it is off for more than 4 minutes.
The programs are different, the 1hour program works just fine. The 3hour program has some stops to let the soap sink in.
Any suggestions for this?
Also another question to my former post (right before that one):
Can someone with an english hs110 look into his/her kasa app and compare the provides values with the ones that are listet in home assistant.
I have a german version and the total_energy_kwh value in ha is never equal to any value in the app.
You could feed the consumption values into a statistics sensor and use that as trigger. This should smoothen out these kind of issues.
Other possibility is to run a script as soon as value is below 4 watts. The script should then run a times for a few minutes and then check power consumption again. If consumption is still below 4 watts it triggers the automation.
