source_index
is missing.
Hi, i do not know exactly where i have to search, maybe you can give me a hintā¦
Since the 14.08. three of my dates turned to unknownā¦
Where should i start to search?
configuration.yaml
waste_collection_schedule:
sources:
- name: regioentsorgung_de
args:
city: Baesweiler
street: Pastor-Engelhard-StraĆe
house_number: 7
# - name: ics
# args:
# file: "www/Leerungstermine521772.ics"
customize:
- type: Bioabfall 2-Rad-Behaelter 02-woechentl.
alias: bioabfall
icon: mdi:trash-can
- type: Gruenschnitt-Strassensammlung
alias: gruenschnitt
icon: mdi:trash-can
- type: Gelbe Saecke
alias: gelbesaecke
icon: mdi:trash-can
- type: Papierabfuhr 2-Rad-Behaelter 04-woechentl.
alias: papier
icon: mdi:trash-can
- type: Restabfall 2-Rad-Behaelter 02-woechentl.
alias: restmuell
icon: mdi:trash-can
fetch_time: "04:20"
day_switch_time: "10:00"
Ok,
i found the problem,
my provider changed the name for the trash-categorysā¦
changed the configuration.yaml, restart, working againā¦
You might want to hide your address in the codeā¦ Btw. nice area āim Drei-LƤnder-Eckā!
Hi, I am trying to get the Framework running with Abfallnavi. I tried to run the Python script shown in the documentation, but it does not show the dialogue as it should - so I cannot get the service IDs.
The shell only responds by showing errors
Python3 Version 3.10.12
Pip3 Version 22.0.2
inquirer installed
Would you have an idea what went wrong?
File "/xx/abfallnavi_de.py", line 1, in <module>
NameError: name 'false' is not defined. Did you mean: 'False'?
Thank you very much for this nice framework. I have installed it manually via copying the waste-
collection-scheduler-folders to the /config/custom_components/waste_collection_schedule folder of my HASSIO instance.
I added the waste_collection_scheduler-section to my configuration.yaml. config-check is ok. After restarting HASSIO, all sensors connected to waste_collection_scheduler have the value āunavailableā.
When checking the protocol, I can see the error āwaste_collection_scheduler always returning source not foundā:
I tried three configs, but I am getting the same error for all three:
sources:
- name: Abfallkalender
args:
service_id: mymuell
city_id: 59942
area_id: 59942
sources:
args:
url: https://calendar.google.com/calendar/ical/df9e29879c8d37ecff55d875af17618678d25a6c8c31ac30c75df7a529270d24%40group.calendar.google.com/public/basic.ics
customize:
- type: Biotonne
alias: Biotonne
icon: mdi:trash-can
- type: Gelbe Tonne
alias: GelbeTonne
icon: mdi:recycle
- type: Papiertonne
alias: Papiertonne
icon: mdi:trash-can
fetch_time: "04:00"
sources:
args:
file: "www/Abfallkalender/Abfallkalender_Haag_2023.ics"
customize:
- type: Biotonne
alias: Biotonne
icon: mdi:trash-can
- type: Gelbe Tonne
alias: GelbeTonne
icon: mdi:recycle
- type: Papiertonne
alias: Papiertonne
icon: mdi:trash-can
fetch_time: "04:00"
What am I doing wrong? I have no ideas anymore. Please advise.
Hi Steffen,
Thanks for your answer.
This was my fault in my first post, sorry. It is installed in /config/custom_components/waste_collection_schedule folder. The calender is in the www-folder.
Cheers,
Stefan
Any other ideas? I am cluelessā¦
@StefanDee You have to keep the source name, this is used to identify the source. You renamed it to āAbfallkalenderā.
I have a small problem after updating to the latest version.
I changed the source because I thought it might be the problem, but it aināt.
configuration.yaml
sources:
- name: awb_emsland_de
args:
city: Meppen
street: my street
house_number: 1
customize:
- type: Wertstoffbehaelter
alias: gelbe
icon: mdi:recycle
- type: Papierbehaelter
alias: paper
icon: mdi:trash-can-outline
- type: Bioabfallbehaelter
alias: bio
icon: mdi:flower-outline
- type: Restabfallbehaelter
alias: trash
icon: mdi:trash-can
fetch_time: "04:00"
sensor.yaml
- platform: waste_collection_schedule
details_format: "upcoming"
value_template: "{% if value.daysTo == 0 %}Today{% elif value.daysTo == 1 %}Tomorrow{% else %}in {{value.daysTo}} days{% endif %}"
types:
- gelbe
types:
- paper
types:
- trash
types:
- bio
the error:
Integration error: waste_collection_schedule - Integration 'waste_collection_schedule' not found.
Platform error sensor.waste_collection_schedule - Integration 'waste_collection_schedule' not found.
I donāt have a clue what changed, any help would be very much appreciated.
Solved, the update went sideways, reinstalled and fixed
Apologies for reviving this old post. Where did you find Albaās ICS? All I can see is a PDF calendar or the option to install a mobile app.
A lot of time has passed since then but the custom integration works perfectly to this day. These are my notes from back then. Please access the link and follow my descriptions I maked at the time:
āWebsite [(Abfuhrtermine)] aufrufen und Adresse eingeben und mit Rechtsklick āUntersuchenā
dann Rechtsklick und Element untersuchen um Abfall.io Felder zu finden (Achtung! drei Punkte Felder aufklappen)ā
Die benƶtigten Daten entnehmen und in die Konfiguration Ć¼bernehmen.
My configuration.yaml
sources:
- name: abfall_io
args:
key: 9583a2fa1df97ā¦
f_id_kommune: 32ā¦
f_id_bezirk: 0
f_id_strasse: XXXXStrasse.
f_id_strasse_hnr: 308ā¦
customize:
- type: Wertstofftonne
alias: wertstoffe
icon: mdi:recycle
By the way, this is the better way, because the ICS are always limited in time and would then have to be replaced at the turn of the year.
Greetings
Andreas
I have been using this integration with a static setting and notice that recycle coach was added. This seems a better way of doing it as sometimes ( do to holidays) the dates change.
I do not understand how to get the 4 pickup with the recycle coach.
My current setup:
sources:
- name: static
calendar_title: Garbage-Pickup
args:
type: Garbage
frequency: WEEKLY
weekdays: {MO, TH}
- name: static
calendar_title: Yard-Pickup
args:
type: Yard
frequency: WEEKLY
weekdays: MO
- name: static
calendar_title: Recycle-Pickup
args:
type: Recycle
frequency: WEEKLY
weekdays: WE
- name: static
calendar_title: Branches-Pickup
args:
type: Branches
frequency: WEEKLY
weekdays: TU
- name: recyclecoach_com
args:
street: xxx ave
city: xxxxbeach
state:
# next garbage collection
source_index: 0
details_format: generic
add_days_to: true
value_template: "{{ value.daysTo }}"
types:
- Garbage
# next yard waste collection
source_index: 1
add_days_to: true
types:
- Yard
# next recycle_collection
source_index: 2
add_days_to: true
types:
- Recycle
# next branches collection
source_index: 3
add_days_to: true
types:
- Branches
I have not seen any examples in the docs showing four pickups for the recycle coach.
Thanks.
So āf_id_strasseā and āf_id_strasse_hnrā is just name name and number in plaintext? I also couldnāt finde āf_id_bezirkā in the source code.
Can I just ask, does the lack of a tameside_gov_uk python script suggest that the info is no longer being provided by my local authority?
Hi, im a little bit stuck in a thingy hereā¦
the EBE changeg 1 day but didint update the ics, so i tried to change the day manually, but it didnt work.
can s.o. pls look into it?
value_template: '{% if value.daysTo == 0 %}Heute{% elif value.daysTo == 1 %}Morgen{% else %}in {{value.daysTo}} Tagen{% endif %}'
types:
- Graue Tonne
types:
- Blaue Tonne
types:
- Gelbe Tonne
value_template: '{% if value.daysTo == 0 %}Heute{% elif value.daysTo == 1 %}Morgen{% else %}in {{value.daysTo - 1}} Tagen{% endif %}'
types:
- Braune Tonne
value_template: 'am: {{value.date.strftime("%d.%m.%Y")}}'
types:
- Graue Tonne
types:
- Gelbe Tonne
name: Braune Tonne Datum
value_template: 'am: {{ (value.date - timedelta(days=1)).strftime("%d.%m.%Y") }}'
types:
- Braune Tonne
name: Blaue Tonne Datum
types:
- Blaue Tonne
Bio Abfall should be showing today and not tomorrow???
@nicstreet No, the reason for this is that is not part of an official release yet. You can either switch to the master
branch or copy the file manually.
Releases are scheduled every 6-8 weeks.
