Watch for specific message in homeassistant log
So I happened to be looking for something else in my log today and noticed this:
## Log Details (WARNING)
Logger: homeassistant.components.hue.light
Source: components/hue/light.py:121
Integration: Philips Hue ([documentation](https://www.home-assistant.io/integrations/hue), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+hue%22))
First occurred: 19:08:49 (1 occurrences)
Last logged: 19:08:49
Please check for software updates of the Dining wall wash bulb in the Philips Hue App.
I had no idea there was an update available or how long it’s been available for. I also didn’t know that HA would be aware of a Hue update and log it. I didn’t get any other notification (e.g. from hue) that an update was available. I haven’t opened the Hue app in months.
Is there a way to watch the log for this message and display it in a lovelace card?
You may use conditional messages from system logs:
And I think that HA is not aware of hue updates. It is just that a recent update which fixes a security issue has been released and devs though it was nice to tell you about.
Aha, that’s perfect, thanks!
Hi, can someone please give an example of how to catch such a warning message in the log? I’m trying to create an automation for notify of a hue bulb sw update based on log message but I get this error:
Error while executing automation automation.create_notifications_for_hue: Error rendering data template: UndefinedError: 'dict object' has no attribute 'event'
The message in the log that I am trying to catch:
Source: components/hue/light.py:299
Integration: Philips Hue (documentation, issues)
First occurred: 16:45:29 (1 occurrences)
Last logged: 16:45:29
Please check for software updates of the Hall bulb in the Philips Hue App.
Automation for this event:
- alias: "Notifications of a HUE update"
    platform: event
    event_type: system_log_event
    event_data:
      level: WARNING
  condition:
    condition: template
    value_template: '{{ "Philips Hue App" in trigger.event.data.message }}'
    - service: notify.telegram
        message: "LOG MSG: {{ trigger.event.data.message }}."
Does anyone have an idea why this doesn’t work?
Did you set fire_event to True under system_log in your config file?
Yes, the fire_event is set to true. I don’t think that error would have occurred without that setting.
 system_log:
  fire_event: true
Ah OK I see. Missing [0] after message in trigger.event.data.message. So should be trigger.event.data.message[0] perhaps?
Good point, but this will cause the same error. I’m not sure what exactly it means: ‘dict object’ has no attribute ‘event’
